メインコンテンツにスキップ
MacBook Proの13インチディスプレイ搭載モデルの修理情報・ガイドです。
9745回答 すべてを表示
Usb / SD Ports damaged
Hello,
2 weeks ago I found out that my sd card was stuck in my macbook pro. I didn't kow why, but it was stuck.
After a lot of safely pulling the sd card got out, but since then my sd port and my usb ports has been damaged.
If I put my external HDD in one of the usb ports, and I move my laptop a little bit or I replace the HDD, I get the warning that I not proper eject my HDD.
So, both my usb ports and my sd port are damaged, is there a way I can fix this?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
Can you supply the last four digits of your serial number so we can correctly ID your system. Depending on what you have you will either need a new main logic board or a I/O board.
さんによる
コメントを追加
1 件の回答
ベストアンサー
If you pulled too hard then you might have loosened multiple solder joints between the connectors and the ports. This would only be repaired by replacing the logic board. If you move the USB cable around can you see the cage that the USB end goes into move around. This may signify that it is loose and/or broken. You can even remove the bottom cover and look for any readily apparent damage on the underside of the board. Here is the guide for removing the bottom panel on the MacBook Pro;
MacBook Pro 13インチ Unibody Mid 2010の下部ケースの交換
and you can compare it to this photo which should show you any damage that is there:
http://www.google.com/imgres?um=1&hl=en&...
.... it's a long link because google wont let me attach it.
Hope this Helps
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
This is for the 2010 model which may not be the exact same as the 2011 or 2012 model that you have. If you could provide us with the last four digits of your serial number then I will update the picture and link to fit your model.
さんによる
コメントを追加
回答を追加する
Pasquale さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 2,076
