Usb / SD Ports damaged
Hello,
2 weeks ago I found out that my sd card was stuck in my macbook pro. I didn't kow why, but it was stuck.
After a lot of safely pulling the sd card got out, but since then my sd port and my usb ports has been damaged.
If I put my external HDD in one of the usb ports, and I move my laptop a little bit or I replace the HDD, I get the warning that I not proper eject my HDD.
So, both my usb ports and my sd port are damaged, is there a way I can fix this?
この質問は役に立ちましたか?
1件のコメント
Can you supply the last four digits of your serial number so we can correctly ID your system. Depending on what you have you will either need a new main logic board or a I/O board.
Dan さんによる
