メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Kinectは、Microsoft Xbox 360用のゲーム周辺機器です。オーディオおよびビデオ入力を可能にし、プレイヤー自身がコントローラーとして機能します。
Two Question About Kinect For Xbox 360?
i have two question about kinect
1- if i connected the kinect for xbox 360 to computer, is there any damage could happned to kinect ??
2- is there any solution or hacking for make kinect for xbox 360 work on computer ??
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
4 件のコメント
Is this the same Kinect that you had asked previously about? the one with the burned out chip?
さんによる 共有
yea, my friend give it to someone to fix it and still no answer
さんによる 共有
iam just asking to sure iam right or wrong, i mean what happened to kinect because of me or because of the man who i bought from him the kinect
second i saw videos on youtube about hacking kinect but iam still not sure if that real or fake ???
さんによる 共有
i have another question
is the tools or gears in kinect for xbox 360 is same in kinect for windows and the different is the word on kinect (xbox 360, kinect) ????
さんによる 共有
コメントを追加
3件の回答
ベストアンサー
The kinect is made for the xbox but aswell as the computer, to get it to work simply plug it in and let windows download the correct software and drivers. If it does not install you then need to download the drivers at windows.com.
The kinect for the computer come's with a SDK for scripting code for small games or applications.
I seen someone script a automated turret with it loaded with a nerf gun lol.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
FF90 thank you
can you give me direct link for drivers ??
さんによる 共有
Drivers - Link
<space> .NET - Link (required to work)
さんによる 共有
thanks for help but iam still confused
さんによる 共有
コメントを追加
最も参考になった回答
FF90 is right, even so that the Kinect for the PC differs somewhat from the xBox Kinect. If you want to try to connect the Xbox Kinect to your computer, check on here for the requirements and software. To get a adpater for the Xbox to PC check on here. Do not expect to find very many games that will support this yet, and most of the software is still custom.Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 4
14 件のコメント:
thank you for help me
さんによる 共有
さんによる 共有
there is no different product version that you can buy for a different platform. its compatible with both platforms on the same device
さんによる 共有
wow specifically says "NOT FOR USE WITH XBOX360" i learn something new everyday, i wonder if i can use the new SDK 1.5 with my original xbox kinect?
さんによる 共有
9件以上のコメントを表示
コメントを追加
No damage can occur from plugging the Kinect in to your computer, but unless you have the necessary drivers installed, you won't be able to do much.
Please visit OpenNI for information about an open source Kinect platform.
The book Making Things See is a very good resource for getting started with hacking the Kinect.
I personally have been able to write a few small programs to use the functionality of the Kinect to perform other tasks on the computer.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
i said that to the man who i bought from him kinect but he don't believe me, he said he plugin the adapter in jack and it's working and the damage i'm responsible of it, all i did it i put adapter in jack and connected the cable in usb and no answer from kinect no move no light nothing but the adapter working and and the lamb in cable is lighten but no response from kinect
any way thanks for help and after my kinect is fix and i think it's impossible i will try to connect it again to computer
さんによる 共有
コメントを追加
回答を追加する
Islam Abou Seada さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 12
今までの合計 2,262
