メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Xbox Originalは、Microsoft初の広く普及したビデオゲームシステムです。上部と前面に「XBOX」のロゴが入った、識別しやすい黒いケースが特徴です。一般的な工具で簡単に修理できます。
Drive opens and closes constantly
Hi,
my original xbox drive once turned on and you press the eject button, the tray opens and then closes constantly and does not stop unless you switch off the unit.
there is no way to stop it from opening and closing.
what do you see as the issue? do I need to replace my drive?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
there are some sensors that tell the Xbox/cd drive that is need to be closed because of pressure or that it can't close. My guess is that those sensors are not working properly. For starters I would suggest opening it and cleaning the cd drive, there might be some dust or something there (and you might as well clean the rest while you're at it). If that does not work, you might have to replace the drive, which will be cheapest to buy a non-functional xbox and taking it out of it.
I don't work on xboxes so don't take my word as gospel, if anyone else has a better idea/explanation, go ahead.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
If the Xbox casing is pressing to hard on the disc drive, it will cause this problem, as it impairs the disc drive pressure sensor, make sure nothing is pressing the disc drive before closing the casing after opening your Xbox :)
さんによる 共有
コメントを追加
回答を追加する
Anthony さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 52
今までの合計 11,333
