学生によって寄稿されたWiki
iFixit学生教育プログラムに参加している素晴らしい学生チームが、このWikiを作成しました。
Loose Backplate
Dropped the camera on its edge, denting the case, and making it no longer waterproof.
Follow the Olympus Tough TG-1 Backplate Replacement
Broken Clip
Check to see if the back plate can be placed back onto the camera. Make sure there are an even number of clips physically on the back plate. If one or more clips seemed to have been broken, then the back plate needs to be replaced. Follow the Olympus Tough TG-1 Clip Slip Replacement
Mode Dial
If the mode dial falls off, and it is not possible to reattach, replace it immediately as your camera may not be water proof anymore. Follow the Olympus Tough TG-1 Circuit Board For Back Buttons Replacement
Dead/Cracked Screen
Dropped the camera making images blurry and no longer weather proof. Follow the Olympus Tough TG-1 Screen Replacement
Screen is Cracked
If the LCD screen is cracked, you need to replace it. Follow the Olympus Tough TG-1 Screen Replacement.
Loose Compartment Door
Battery falls out unexpectedly.
Follow the Olympus Tough TG-1 Battery Replacement
Battery and Memory Cards Left Exposed
If the door covering is broken, whether it be the clips, or the pin is simply broken. Replace it if you care to take your camera out for strenuous activities. Follow the Olympus Tough TG-1 Battery Replacement
Lock Tab
If the locks on the door are loose and not securing the compartment door, replace them. These mechanical pieces will shelter items that are very sensitive to water. Follow the Olympus Tough TG-1 Battery Replacement
Useless controls
Knobs/buttons become unresponsive Follow the Olympus Tough TG-1 Circuit Board For Back Buttons Replacement
Replacing Circuit Board
If your basic input for the hardware is not showing any output, then chances are something is malfunctioned internally. For the back plate housing the LCD screen, there are two pieces of circuitry: one for the screen itself, and the other for the physical buttons on the back plate. The circuit board for the physical buttons has to be replaced. Follow the Olympus Tough TG-1 Circuit Board For Back Buttons Replacement
Issues With Focusing
The lens no longer adjusts to zoom in and out. Follow the Olympus Tough TG-1 Circuit Board For Back Buttons Replacement
Circular Lens Protector
If one of the plastic tabs on the circular lens breaks, replace it so that dust and water do not protrude the circular hole. Follow the Olympus Tough TG-1 Lens Box Replacement
2 件のコメント
My problem is not on here. My problem is that if I’m video recording and I zoom in or out while actually recording than the camera refuses to write the video to the sd card. It just says “busy” forever. It didn’t do this when I bought it. It doesn’t have a problem writing to the disk if I don’t zoom while video recording.
Adventure Team - 返信
My problem is also not on here. Similar to the above comment, but not exactly the same. While recording it will randomly at times say “busy” & just stop recording. It writes all the info up to that point, but just ends the recording at that point. It doesn’t always do this, seems quite sporadic & only recently started doing it after years of use.
Sean - 返信
