メインコンテンツにスキップ
Olympus Tough TG-1 Screen Replacement
必要な工具と部品
  1. Olympus Tough TG-1 Screen Replacement, Clip Side Repair: 手順 1、 2の画像 1 Olympus Tough TG-1 Screen Replacement, Clip Side Repair: 手順 1、 2の画像 2
    • Remove both 6 mm screws from the clip side of the camera.
    • After you have removed the two screws, remove both the clip and the plate behind the clip so that the inside of the camera is exposed.
    • If one of more of the clips appear to be broken, the back plate might need to be replaced.
  2. Olympus Tough TG-1 Screen Replacement, Top of Camera: 手順 2、 1の画像 1
    • The top of the camera does not contain screws. You do not need to remove anything from the top of the camera.
  3. Olympus Tough TG-1 Screen Replacement, Plug Side: 手順 3、 3の画像 1 Olympus Tough TG-1 Screen Replacement, Plug Side: 手順 3、 3の画像 2 Olympus Tough TG-1 Screen Replacement, Plug Side: 手順 3、 3の画像 3
    • Remove the two 5 mm screws on the side of the camera with the plug.
    • Open the compartment door and remove both 6 cm screws inside of the compartment door. This will allow you to remove the tan piece held by the screws.
  4. Olympus Tough TG-1 Screen Replacement, Bottom: 手順 4、 1の画像 1
    • Turn the camera so that you are looking at the bottom of the camera.
    • Remove the two 4 mm screws from the bottom of the camera.
    • The screws are different. The rear screw is has an unthreaded shank to locate the outer shell while screwing into the inner frame.
  5. Olympus Tough TG-1 Screen Replacement, Front Panel: 手順 5、 3の画像 1 Olympus Tough TG-1 Screen Replacement, Front Panel: 手順 5、 3の画像 2 Olympus Tough TG-1 Screen Replacement, Front Panel: 手順 5、 3の画像 3
    • Use the plastic opening tool to remove both components of the front panel. This includes the black part on the outside of the front panel and the main silver panel.
    • Once every screw and panel is removed, you can replace the backplate to make your camera weatherproof again.
  6. Olympus Tough TG-1 Screen Replacement, Opening the Internal Case: 手順 6、 3の画像 1 Olympus Tough TG-1 Screen Replacement, Opening the Internal Case: 手順 6、 3の画像 2 Olympus Tough TG-1 Screen Replacement, Opening the Internal Case: 手順 6、 3の画像 3
    • Using the plastic opening tools, carefully open the case.
    • Do not tear the white circuit ribbon.
  7. Olympus Tough TG-1 Screen Replacement, Opening the Screen's Protective Cover: 手順 7、 3の画像 1 Olympus Tough TG-1 Screen Replacement, Opening the Screen's Protective Cover: 手順 7、 3の画像 2 Olympus Tough TG-1 Screen Replacement, Opening the Screen's Protective Cover: 手順 7、 3の画像 3
    • Using the screwdriver, remove the ten 3mm anchor screws.
    • Using the plastic opening tool, open the protective cover so that the screen is exposed.
  8. Olympus Tough TG-1 Screen Replacement, Unclipping the Screen from the Circuit Ribbon: 手順 8、 1の画像 1
    • Carefully unclip the screen from its circuit ribbon.
終わりに
作成者
5人の作成者と共同で作成されました。
Emily Gensch
メンバー登録日: 01/21/15
116 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 4-6, Brown Winter 2015 USF Tampa, Team 4-6, Brown Winter 2015人のメンバー
USFT-BROWN-W15S4G6
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 16
今までの合計 2,317
