メインコンテンツにスキップ
The controller won't turn on
Controller doesn't turn on or respond to button input.
Bad batteries
Turn on power switch and make sure the Power light turns on. If the light doesn’t turn on, try replacing the batteries.
Bad motherboard or loose connections
If replacing the batteries doesn't work, the problem is hard to diagnose. There are many possible causes for the controller not to turn on including a bad switch, a bad motherboard, a bad connection somewhere inside the controller, or a bad electrical component.
The controller turns on but doesn't work
The power light turns on, but the controller doesn't respond.
Wireless signal is blocked
Make sure the receiver is fully plugged in to the GameCube.
Press a button on the controller. The small light on the receiver should flash.
If the light doesn't flash, make sure the controller is within 20 feet of the receiver and try again.
Channels don't match
Make sure the channel wheels on the controller and receiver match.
If the light still won't flash, try using a different channel.
If you are using multiple wireless controllers, make sure they are set to different channels.
Bad motherboard
If you cannot get any response from the controller, try replacing the motherboard.
The channel wheel on the controller or receiver won't turn
The channel wheel is stuck in place.
Dirt is clogging the wheel
Make sure the area around the controller wheel is cleaned of gunk. Use a pin or needle to clear the area around the wheel of any dirt.
Bad wheel
If wheel still will not turn, try replacing the wheel.
The buttons are sticking or not responding
When you press a button it is slow to come back up or nothing happens.
Dirt is clogging the buttons
Make sure the area around the buttons are clear of gunk. Use a pin or needle to scrape any dirt out of the space around the buttons.
Bad buttons
If buttons still stick or don't respond, try replacing the buttons.
The joystick/C-Stick isn't working
When you move the joystick/C-Stick, the character won't respond.
Dirt is clogging the joystick/C-Stick
Make sure the joystick/C-Stick is cleaned of any visible gunk. Use rubbing alcohol and a Q-tip or cloth to scrub the base of the joystick/C-Stick. Rotate the joystick/C-Stick as you scrub to clean all sides.
If the joystick/C-Stick is still sticky, there may be dirt inside of the joystick/C-Stick. To clean this, use the joystick installation guide to remove the joystick or the C-Stick installation guide to remove the C-Stick. You can now clean the joystick/C-stick with rubbing alcohol.
Bad joystick/C-Stick
If cleaning the joystick/C-Stick doesn't help, try replacing it with the joystick installation guide or the C-Stick installation guide, respectively.
The joystick is giving wrong input
The game character moves when you're not touching the joystick or moves in the wrong direction.
The joystick is oriented wrong
Re-orient joystick on GameCube menu. This should stop any rogue input from the joystick.
Turn the controller off. Turn it back on while the joystick is in the neutral position. If you start a game with the joystick off center, the game will take that new position as neutral. This will make your character move when you take your thumb off of the joystick. Another way to reset the joystick calibration is to press and hold the "X", "Y", and "start/pause" buttons simultaneously for 3-5 seconds. This method also works for the wired variety of GameCube controller.
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
2 件のコメント
I have i problrm eit wireless joystick,an when i conneci it it sen to work,bit in game camer go crazy it turn around instantly,other function work any idea?
obregr - 返信 共有
I’m having a strange issue where the receiver is lighting up and receiving input on every press, but getting no reaction after that on the Gamecube
Evan James - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 15
過去 30 日: 98
今までの合計 32,291
