メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Nintendo WaveBird Wireless Controller Channel Wheel Replacement
必要な工具と部品
  1. Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Batteries: 手順 1、 2の画像 1 Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Batteries: 手順 1、 2の画像 2
    • Pull down on the battery cover release lever and pull back to remove the cover.
    FixBotに聞いてみる
    コメントを追加
  2. Nintendo WaveBird Wireless Controller Channel Wheel Replacement: 手順 2、 1の画像 1
    • Remove both batteries from the device.
    FixBotに聞いてみる
    コメントを追加
  3. Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Front Panel: 手順 3、 2の画像 1 Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Front Panel: 手順 3、 2の画像 2
    • Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
    • During reassembly, firmly hold the panels of the controller together while replacing the screws so the panels do not separate.
    FixBotに聞いてみる
    コメントを追加
  4. Nintendo WaveBird Wireless Controller Channel Wheel Replacement: 手順 4、 2の画像 1 Nintendo WaveBird Wireless Controller Channel Wheel Replacement: 手順 4、 2の画像 2
    • Carefully turn over the controller and place it on a flat surface.
    • Slowly separate the top panel from the bottom panel.
    • The buttons are loose and may fall off the motherboard.
    • Once separated, set aside the top panel.
    • During reassembly, make sure the front panel lines up with the buttons so they slide back into place.
    FixBotに聞いてみる
    コメントを追加
  5. Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Buttons: 手順 5、 3の画像 1 Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Buttons: 手順 5、 3の画像 2 Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Buttons: 手順 5、 3の画像 3
    この手順で使用する道具:
    • Use tweezers to remove the buttons.
    • It may be easier to remove the A button off of the pad by lifting it with your fingers.
    • During reassembly, make sure all buttons are in their respective sockets so they match up with the front panel.
    FixBotに聞いてみる
    コメントを追加
  6. Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Motherboard: 手順 6、 1の画像 1
    この手順で使用する道具:
    • Using tweezers remove the three grey button pads from the motherboard.
    FixBotに聞いてみる
    コメントを追加
  7. Nintendo WaveBird Wireless Controller Channel Wheel Replacement: 手順 7、 1の画像 1
    • With your fingers gently grip the motherboard on both sides and lift it away from the back panel.
    • To put the motherboard back into place, align the two metal clips under the motherboard with the slots in the back panel. The motherboard should fall into place.
    FixBotに聞いてみる
    コメントを追加
  8. Nintendo WaveBird Wireless Controller Channel Wheel Replacement, Channel Wheel: 手順 8、 1の画像 1
    • Turn the motherboard over so the channel wheel is facing up.
    FixBotに聞いてみる
    コメントを追加
  9. Nintendo WaveBird Wireless Controller Channel Wheel Replacement: 手順 9、 2の画像 1 Nintendo WaveBird Wireless Controller Channel Wheel Replacement: 手順 9、 2の画像 2
    • Pinch the wheel and pull it away from the motherboard.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
8人の作成者と共同で作成されました。
Travis Taylor
メンバー登録日: 04/12/13
539 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 10-40, Amido Spring 2013 Cal Poly, Team 10-40, Amido Spring 2013人のメンバー
CPSU-AMIDO-S13S10G40
4 メンバー
37のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 45
今までの合計 2,729
