DYMO® LetraTag®
DYMO® LetraTag® ラベルライターは、家庭やオフィスでの使用向けに設計されています。ハンディタイプの LetraTag® 200B、LetraTag® 100H、LetraTag® 100T、および LetraTag® 100H Plus について紹介します。
過去 24時間: 2
過去 7 日: 20
過去 30 日: 87
今までの合計 896
2 件のコメント
Please advice, I disassembled the machine, and found a loose spring. I found out that the spring is used to retract the cutter after cutting. But I can't figure out the correct placement of the spring. Does anyone know? It is the handheld version.
Lemonoius - 返信 共有
Now I know. Disassemble completely the cutter handle and remove the white part. Then remove the circuit board part from the tape holder. Then the cutter mechanism will come out, and the spring belongs inside the part the blade is fastened to. Use this video to disassemble. https://www.youtube.com/watch?v=UoRt52zM...
Lemonoius - 返信 共有
