メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのGoogle Pixel Cを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Google Pixel C Teardown, Google Pixel C Teardown: 手順 1、 2の画像 1 Google Pixel C Teardown, Google Pixel C Teardown: 手順 1、 2の画像 2
    • What makes a Pixel C? Let's see!
    • 10.2" LTPS LCD with a resolution of 2560 x 1800 (308 ppi)
    • Nvidia Tegra X1 64-bit quad-core processor paired with a 256-core Maxwell GPU
    • 3 GB LPDDR4 memory
    • 32 or 64 GB storage options
    • USB Type-C
    • 8 MP rear camera and 2 MP front camera
    • Android 6.0 Marshmallow
  2. Google Pixel C Teardown: 手順 2、 3の画像 1 Google Pixel C Teardown: 手順 2、 3の画像 2 Google Pixel C Teardown: 手順 2、 3の画像 3
    この手順で使用する道具:
    iOpener
    $17.99
    • The Pixel C features a slick unibody aluminum chassis, with stereo speakers, USB C, and the usual power and volume rockers.
    • Along the top are holes for the "quad noise-cancelling microphones." Interesting feature for a device that doesn't yet support always-on "OK Google."
    • (Apparently this feature is "coming soon.")
    • We've seen dual microphones in devices for a few years now, a feature that cancels out ambient noise by comparing signals from two different locations. Four is a bigger number than two, so it probably does it better.
    • But enough of the outside—let's slap some heat on this fondleslab and open it up.
  3. Google Pixel C Teardown: 手順 3、 3の画像 1 Google Pixel C Teardown: 手順 3、 3の画像 2 Google Pixel C Teardown: 手順 3、 3の画像 3
    この手順で使用する道具:
    Heavy-Duty Suction Cups (Pair)
    $14.95
    • After much heating and some heavy duty suction, we have liftoff!
    • Alas, we seem to be tethered to the launchpad: a thin cable for the front-facing camera keeps us from immediate opening success.
    • A bit of deft spudgering is called for.
    • With the camera cable dispatched, we're able to open the Pixel C, with the wide display data ribbon cable still attached.
    • And get a look at that adhesive—thick, gooey, and plentiful. No wonder this was a tough nut to crack.
  4. Google Pixel C Teardown: 手順 4、 3の画像 1 Google Pixel C Teardown: 手順 4、 3の画像 2 Google Pixel C Teardown: 手順 4、 3の画像 3
    • Unlike most other tablets we've seen, the Pixel C's front-facing camera assembly lives on the display, not within the device's unibody chassis.
    • That makes for an annoying extra cable to disconnect when opening the device.
    • The front-facing camera assembly contains a 2 MP selfie cam, ambient light sensor, and what looks like a camera indicator LED.
    • A small daughterboard connects the display data cable and is host to the Synaptics touchscreen controller (S3370B).
  5. Google Pixel C Teardown: 手順 5、 2の画像 1 Google Pixel C Teardown: 手順 5、 2の画像 2
    • Display dispatched, we get a better look at the goods.
    • In the interest of safety, we decide to disconnect the battery first—no easy task.
    • The connector is buried under two ribbon cables and a piece of tape.
    • And an exploratory battery poke tells us those cells are very solidly adhered to the case... We'll save that chore for later...
    • There are a total of 17 magnets spread out through the whole case to allow for connecting it to the keyboard.
  6. Google Pixel C Teardown: 手順 6、 3の画像 1 Google Pixel C Teardown: 手順 6、 3の画像 2 Google Pixel C Teardown: 手順 6、 3の画像 3
    • Where to next? Perhaps those fancy stereo speakers.
    • The speakers are home to adhered-on antennas, so replacing the speaker will probably mean a bit of extra work in the form of peeling and re-sticking.
    • The speakers' backs are covered in spring contacts that all connect to the back of the case—perhaps for grounding or for conducting WiFi signal to the antennas.
  7. Google Pixel C Teardown: 手順 7、 3の画像 1 Google Pixel C Teardown: 手順 7、 3の画像 2 Google Pixel C Teardown: 手順 7、 3の画像 3
    • A couple standard Phillips screws secure the USB-C port bracket—but after that, the removal is painless and very modular.
    • We love seeing ports as separate parts! This port will likely get a lot of abuse throughout its life, and a modular component means it can be replaced with relative ease, at low cost (assuming you can get the device open without breaking the display...)
  8. Google Pixel C Teardown: 手順 8、 3の画像 1 Google Pixel C Teardown: 手順 8、 3の画像 2 Google Pixel C Teardown: 手順 8、 3の画像 3
    • More modular components ahead!
    • The rear-facing camera comes out of its hutch after taking off the metal bracket keeping it in place.
    • We continue to be confused about tablet cameras—but at 8 MP, you can take pretty decent photos of your cats without grabbing your phone.
    • The power button and volume rocker are simply fixed with two screws apiece. Short cables and simple button covers will make replacements a breeze.
  9. Google Pixel C Teardown: 手順 9、 2の画像 1 Google Pixel C Teardown: 手順 9、 2の画像 2
    • After a honeymoon of modular parts, we encounter a rough patch: an adhered motherboard.
    • And a black one at that! We're having Apple product flashbacks. At least the USB port was modular.
    • No screws to be found, we opt for some heat action.
    • We finally pry out the heart of the tablet, wresting it from two adhesive pads, some (nonstick) foam padding and a couple strips of conductive foam.
  10. Google Pixel C Teardown: 手順 10、 2の画像 1 Google Pixel C Teardown: 手順 10、 2の画像 2
    • Major players on the board:
    • Samsung KLMBG4GEND 32 GB eMMC flash storage
    • Samsung K4F2E304HMMGCH 6 Gb (1.5 GB) LPDDR4 RAM (x2 for 3 GB total)
    • Broadcom BCM43540LKUBG 5G Wi-Fi 802.11ac controller
    • Nuvoton NAU88L25 audio codec
    • STMicroelectronics STM32F3x8 32 bit ARM Cortex-M4 microcontroller
    • Infineon SLB 9645 trusted platform module
    could this RAM can change to 8GB?
    十六稚枫无 - 返信
  11. Google Pixel C Teardown: 手順 11、 2の画像 1 Google Pixel C Teardown: 手順 11、 2の画像 2
    • IC Identification, pt. 2:
    • Realtek ALCxxxx card reader controller
    • Analog Devices audio amplifier (likely)
    • Maxim Integrated MAX77620A power management
    • Maxim Integrated MAX77621A power management
    • Diodes Incorporated PI3USB30532 USB 3.2 Type-C analog switch
    • Diodes Incorporated PI3USB9281C USB port protection w/ charger detection
    • Winbond W25Q128FW 128 Mb Serial NOR flash memory
  12. Google Pixel C Teardown: 手順 12、 2の画像 1 Google Pixel C Teardown: 手順 12、 2の画像 2
    • IC Identification, pt. 3 (sensors):
    • Bosch Sensortec BMI160 3-axis accelerometer/gyroscope
    • Bosch Sensortec BMM150 3-axis magnetometer
    • Texas Instruments TMP451 temperature sensor
  13. Google Pixel C Teardown: 手順 13、 3の画像 1 Google Pixel C Teardown: 手順 13、 3の画像 2 Google Pixel C Teardown: 手順 13、 3の画像 3
    • This neat little coil feeds the Pixel C's parasitic keyboard, when it's connected in the proper screen-covering position.
    • Having no ports of its own, the keyboard needs inductive charging from the tablet to function. We'll find a twin to this coil in the peripheral.
    • Under the coil, we find a control board—probably responsible for turning boring old DC power from the battery into exciting, varying-magnetic-field-generating AC to power the coil.
    • Chips found on this PCB include a STMicroelectronics STM8S003F3 8-bit microcontroller, a Semtech TS32101 DC-DC boost converter, and a Semtech TS51231 wireless power system transmitter.
    • We also get to peel out this record-breaking headphone jack port with the longest tail ever.
    • It actually does double duty as an interconnect cable for the inductive coil and the right speaker.
  14. Google Pixel C Teardown: 手順 14、 3の画像 1 Google Pixel C Teardown: 手順 14、 3の画像 2 Google Pixel C Teardown: 手順 14、 3の画像 3
    • This portion of the case seems to be geologically interesting; under the headphone jack crust, we find a reflective backing covering an LED board.
    • But wait—those LEDs point up at the display, not toward the indicator bar in the case. That seems weird.
    • The shiny foil layer actually traps the light from the board and bounces it back down to a light guide that shines out through the case.
    • The final stratum is an array of four noise-canceling microphones.
    • Who knows if doubling the microphones will actually double the performance from the standard dual-microphone array.
  15. Google Pixel C Teardown: 手順 15、 2の画像 1 Google Pixel C Teardown: 手順 15、 2の画像 2
    この手順で使用する道具:
    Plastic Cards
    $2.99
    • We're finally ready to tackle that hefty battery, but first let's peep those specs.
    • At 34.2 Wh, the Pixel C handily beats the 27.9 Wh 9.7" iPad Pro, but comes in behind the Surface Pro 4's 38.2 Wh powerhouse.
    • After some serious heating, we start scraping along with a plastic card.
    • Even at the shallowest of angles, we start to curl that battery like some pencil shavings. This is some pretty tough adhesive.
    • We decided tomorrow would be a better day for a Li-Ion battery explosion, and stopped here.
    Have you considered doing the opposite for battery removal? Freezing (or near freezing) might make the adhesive brittle while also preserving the rigidity of the battery pack. A cold Li-Ion battery is also less likely to explode, so that's a plus.
    Christian Schaab - 返信
  16. Google Pixel C Teardown: 手順 16、 3の画像 1 Google Pixel C Teardown: 手順 16、 3の画像 2 Google Pixel C Teardown: 手順 16、 3の画像 3
    • Now on to the Pixel C's keyboard. While not included in the base package, it's still worth a peek.
    • With no obvious point of entry, we start prodding, and heating, and prying.
    • A plastic bezel is the first chink in the armor, and it looks like we made a good choice. Already we have an inductive charging coil, and several magnets exposed to the world.
  17. Google Pixel C Teardown: 手順 17、 3の画像 1 Google Pixel C Teardown: 手順 17、 3の画像 2 Google Pixel C Teardown: 手順 17、 3の画像 3
    • Removing a few screws, and adding a lot more heat, gives us ingress into the main body.
    • And the keyboard lifts right up—no pesky cables connect the keyboard to the bottom case, and none run near the prying edges. Phew!
    • The big cable is for the keyboard, but what about that thinner one?
    • The narrow cable lines up with a magnet in the Pixel C's case—so, our bets are on Hall effect sensor. This way, the keyboard instantly knows it's attached to the tablet, so "you can start typing in an instant."
  18. Google Pixel C Teardown: 手順 18、 3の画像 1 Google Pixel C Teardown: 手順 18、 3の画像 2 Google Pixel C Teardown: 手順 18、 3の画像 3
    • With an opening pick we can simply pop off the single keys.
    • Behind it we find the traditional scissor mechanism. Larger keys have an additional small metal bar.
    • The keys are also easy to clip on again. We are a bit worried about the tiny plastic clips breaking when trying to insert a key in the wrong orientation.
  19. Google Pixel C Teardown: 手順 19、 3の画像 1 Google Pixel C Teardown: 手順 19、 3の画像 2 Google Pixel C Teardown: 手順 19、 3の画像 3
    • It's looking like the base is just a weight and hinge, while the guts are piggybacked to the keyboard assembly.
    • Ignoring the cables for now, we scoop out the teeny battery.
    • Lacking any specs, we can't tell you much about the battery—other than, well, it's small. And inductively charged by the tablet.
  20. Google Pixel C Teardown: 手順 20、 3の画像 1 Google Pixel C Teardown: 手順 20、 3の画像 2 Google Pixel C Teardown: 手順 20、 3の画像 3
    • Dispatching the keyboard and sensor cable, we pop the main board—and attached inductive charging coil—from the keyboard.
    • And the brains of this (small) beast: Nordic Semiconductor nRF51822 2.4 GHz Bluetooth and 32 bit ARM Cortex-M0 microcontroller
    • Semtech TS51221 wireless power receiver voltage regulator
    • STMicroelectronics BAL-NRF01D3 50 Ω Bluetooth balun
    • Dialog Semiconductor (formerly Silego) SLG46110 Programmable mixed signal array (likely)
    • Texas Instruments LP5907SNX-3.3 250 mA / 3.3 V LDO regulator
  21. Google Pixel C Teardown: 手順 21、 3の画像 1 Google Pixel C Teardown: 手順 21、 3の画像 2 Google Pixel C Teardown: 手順 21、 3の画像 3
    • Final frontier: the tablet mount hinge.
    • As with the rest of this keyboard, it's packed with glue, but after a heating marathon we manage to pry the hinge components apart.
    • Under the cover we find: many more magnets! Google really wants this tablet to sit securely...
    • This snappy layout gives you a good idea of the simple, but solid, construction of this peripheral.
  22. Google Pixel C Teardown: 手順 22、 2の画像 1 Google Pixel C Teardown: 手順 22、 2の画像 2
    • The Pixel C Repairability Score: 4 out of 10 (10 is best):
    • Many parts, including the USB-C port, are modular and can be replaced independently.
    • The motherboard is glued tightly to the rear case.
    • Crazy strong adhesive holds the battery to the rear case, complicating the inevitable replacement.
    • The fused display must be removed to access any interior parts—no easy task, thanks to tough adhesive.
作成者
8人の作成者と共同で作成されました。
Tobias Isakeit
メンバー登録日: 03/31/14
124,028 ポイント
189のガイドは作成済み
チーム
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer人のメンバー
Business
1 メンバー
1,131のガイドは作成済み
19 件のコメント
Nexus, can't go wrong. I love it. <3
jvelez - 返信
Are you sure of "noise cancelling mic"? Noise cancelling is more about mics in different directions and defining a main one, like the iPhone with it's top, bottom (main), rear ones (still this only works when not in speakerphone, since then you can't define which the main one is).
Coupling mics together is more about get louder audio without increasing mic sensibility (what makes a better quality audio) and stereo effect. It's a tablet, it's like being always in speakerphone, after all.
Fernando - 返信
I love my Nexus 10 too! Best tablet I have ever had. (Replaced iPad)
Sergio Marcelo - 返信
Do you know where can I find parts for Pixel C? I need another usb type C port.
Viacheslav Kim - 返信
The keyboard teardown doesn't show how a single key is fixed to the keyboard. Are the keys glued or removable and re-attachable to the keyboard frame? Could you illustrate this process also?
mmatzat - 返信
We added one more step to show the removal of the keys and the underlying mechanism.
Tobias Isakeit -
Thank you for the additional information. I will try to fix my jammed key now.
Mathias Matzat -
Where can I find the screen
abarca951 - 返信
Where can I find the screen ?
abarca951 - 返信
Please tell us where we can buy a replacement Screen? Please Please Please!
Krypto Graphic - 返信
Great teardown, very informative.
Any idea why some of tablets are having the screen clicking issue when pushed slightly? Mine does this starting about 1/5 from the left side - approximately where the motherboard ends and battery starts.
Is it the screen itself or the components/space behind it?
Jānis Klemka - 返信
Did you identify the chips used in the wireless power?
Zen Turtle - 返信
I'm looking for keycaps for the keyboard. Is this same keyboard used anywhere else? I can't find anyone selling replacements for the Pixel C
Temp Orary - 返信
You can't find a replacement screen anywhere. No one sells it and no one repairs it if the screen breaks at all your SOL
Mike Oxley - 返信
Where do we get the replacement parts for this tablet?
Michael T - 返信
How does one replace the Google Pixel C swollen battery?
Daniel Renninger - 返信
I looked for a replacement screen on the Internet for a while. The only replacement screens I found were from some company in India that doesn’t seem to ship internationally. There is literally no one who sells replacement screens for the Pixel C. What I did was I searched ebay, CL, OfferUp, ect for weeks looking for someone selling a Pixel C as a parts tablet. Most that youll find will be a parts tablet because of a screen problem… but I eventually found one. I bid on the auction and won it for $76. I will now seek professional assistance with the replacement. It was so hard to find the part that I dont want to f this up!
Alicia - 返信
Hi Alicia! thank you. I am looking for screen replacement also
Virginia Bon -
hey! another one with the same screen problem here, I open the tablet but in the process i burn a liltle bit the screen so there is no way to use the tablet now. I try to conect it to an USB C hdmi out to my tv but there is no MHL support so I cant see it on my TV.
Does somebody know how can I use my tablet at least conected to some place or do something with it? . its a shame such a good hardware being waste like this.
I tried looking for the ribbon cable to HDMI but there is not wires for this either (or at least I havent find it).
thanks for your solutions.
Sorry for my english, im spanish :)
Adrian Gallardo - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 13
過去 30 日: 83
今までの合計 51,844
