メインコンテンツにスキップ
« 全てのストーリーへ戻る
iMac HDD Replacement
Joseph Abraham -
iMac Intel 20" EMC 2133 and 2210
ストーリー画像
iMac Intel 20" EMC 2133 and 2210 Hard Drive Replacement
1時間
Moderate
問題
Original hard drive went bad, had to replace it.
修理
Repair went smooth. However, I did forget to attach one cable prior to reassembly. I had to open the unit back up and reattach the video cable. I ended up actually shocking myself because when I reopened the computer, I forgot to unplug the computer.
Also, wasn't able to install the operating system from the DVD drive for some reason. I ended up cloning a drive that was plugged in via USB; I used disk utility.
アドバイス
First, never work on an iMac when it is plugged in. There is a possibility of lethal electric shock. Second, in many instances, cloning drives with disk utility is more time effective than reinstalling from recovery disk.
4 TB 3.5" Hard Driveの画像
$172.99
« 全てのストーリーへ戻る
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 229
