メインコンテンツにスキップ
« 全てのストーリーへ戻る
Nearly perfect home button replacement
platima -
iPhone 4
ストーリー画像
  • 画像番号1
  • 画像番号2
iPhone 4 Home Button Replacement
2時間
Difficult
問題
The previous home button was old, hard to press, and nearly impossible to double-tap. I also though a white button on a black iPhone would look pretty awesome.
修理
The repair wasn't hard, just took a while. Unfortunately when I put it back together though, the screen was on a slight angle and I have a thin tapered line at the top of the screen as a result (seen in the image).
アドバイス
Yeah, video record what you do so you can play it back if you're unsure about clips, screws, etc. Also be careful that you don't move the LCD panel attached to the front glass and end up with the result I did!
« 全てのストーリーへ戻る
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 12
今までの合計 238
