メインコンテンツにスキップ
« 全てのストーリーへ戻る
Replacing the cooling fans was a easy task.
jaytee0806 -
MacBook Pro 15" Unibody 2.53 GHz Mid 2009
ストーリー画像
  • 画像番号1
  • 画像番号2
  • 画像番号3
MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Fan Replacement
Moderate
問題
The left fan was making a very loud noise. Like the one you hear when you stick a baseball card in a bikes' spoke. But just to be safe I replaced the right fan too even though it wasn't giving me any problems.
修理
The repair was very easy. I removed the screws holding the bottom cover then the three screws holding each of the fans in place. I disconnected the power supply and was able to lift the fans out. I replaced the fans and only screwed the screws in just enough to do a check. I turned on the power and the noise was gone. I finished tightening all the screws and replaced the cover. The entire job took me about 15 minutes. It would have been less if I had my repair tools but I don't where I put them.
アドバイス
Make sure you have the right tools.
MacBook Pro 15" Unibody (2.53 GHz Mid 2009) or 17" Unibody (Early/Mid 2009) Right Fanの画像
$44.99
MacBook Pro 17" Unibody (Early-Mid 2009) Left Fanの画像
$34.99
« 全てのストーリーへ戻る
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 15
今までの合計 123
