メインコンテンツにスキップ
« 全てのストーリーへ戻る
Power supply replacement
lazzeostergaard -
ストーリー画像
  • 画像番号1
  • 画像番号2
  • 画像番号3
問題
I bought an Imac 24 on the Swedish ebay "Tradera" guessing that there was a problem with the power supply. Thanks to the guide here on ifixit I thought that I give it a try so I ordered a new power supply, 3 screwdrivers and suction cups.
修理
Thanks to the guide on ifixit i managed to replace the power supply in half an hour. I was very excited when I first pressed the power button and I could here the apply startup sound, however, the power supply was not the only part that was corrupt. The hard drive was also bad so I had to take the Imac apart one more time to replace the hard drive (had one 1 TB laying around).
アドバイス
It is a good idea to be 2 persons doing this repair. If one can hold the LCD you don't even need to disconnect the LCD. That will save you some time.
T6 Torx Screwdriverの画像
T6 Torx Screwdriver
$9.99
Heavy-Duty Suction Cups (Pair)の画像
$16.95
TR10 Torx Security Screwdriverの画像
$5.99
« 全てのストーリーへ戻る
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 16
今までの合計 57
