メインコンテンツにスキップ
« 全てのストーリーへ戻る
Digitizer disaster
Ken Spires -
iPad Air Wi-Fi
ストーリー画像
iPad Air Wi-Fi Front Panel Assembly Replacement
2時間
Moderate
問題
It was cheaper to fix than replace, plus I LOVE a challenge.
修理
I was a little nervous. I have replaced several iPhone screens, but this was my first iPad. Clear a spot at a bench, spread out a darker colored (lint-free) fabric. I use dark so that tiny screws, etc. will stand out. Also, if you have access to an anti-static mat, that is better.
アドバイス
If you are not using an anti-static mat, be sure anytime you let go of whatever you are working on, you ground yourself to the metal frame before proceeding. Do not rush, follow instructions, BE GENTLE! I used clear packing tape to keep the digitizer together while working with it. It also kept small shards from sticking out and cutting me. Use clear tape so you can still see the LED display. Be diligent when cleaning old glass and seal fragments. Be patient.
« 全てのストーリーへ戻る
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 6
今までの合計 128
