メインコンテンツにスキップ
« 全てのストーリーへ戻る
Sony a65 Main board replacement
HITGFRY -
ストーリー画像
問題
Camera would not power up. I found that the CMOS battery receptacle solder points had come undone. I tried to re-solder but it didn't work. I think the poor connection damaged something else in the mother board. I purchased a manufacturers refurbished MB on eBay for $159.00.
修理
Replaced the main board. It went well but not as fast as the tutorial said but that's to be expected first time through.
アドバイス
DO NOT install the CMOS battery until last thing before you put the plastic covers back on. The battery receptacle will break very easily if you ham hand the battery installation, I broke a tab but was able to secure it with super glue. Make sure you put screws on a non-metallic tray with a lip so they won't roll away and lay them out in order as they are removed.
iFixit Precision 4 mm Screwdriver Bitの画像
$2.99
« 全てのストーリーへ戻る
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 9
今までの合計 387
