メインコンテンツにスキップ
« 全てのストーリーへ戻る
Replaced iPad Air Front Panel
maliawaddell -
iPad Air Wi-Fi
ストーリー画像
  • 画像番号1
  • 画像番号2
  • 画像番号3
iPad Air Wi-Fi Front Panel Assembly Replacement
2時間
Difficult
問題
My iPad had the ghost touching problem, where it just started freaking out and opening apps without being touched. My research pointed to a digitizer problem. I also had a small cracked screen area.
修理
I had mixed results. Eventually I fixed it. Getting the original screen off with all that adhesive was no joke. I also cracked my replacement screen trying to install the home button and had to order another. The home button still doesn't respond as well as the original. But I have a functioning iPad again! So I'll consider it a win.
アドバイス
Definitely order the replacement assy that has the adhesive and home button pre-installed. A razor blade and a blow dryer were my main tools used to remove the screen.
iPad Air Screen Digitizerの画像
$29.99
« 全てのストーリーへ戻る
1件のコメント
Sounds tricky, but glad you worked it out!
Cynthia Replogle - 返信 共有
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 166
