メインコンテンツにスキップ
« 全てのストーリーへ戻る
3GS Mute Button
g15389 -
iPhone 3G
ストーリー画像
  • 画像番号1
  • 画像番号2
iPhone 3G Mute Button Replacement
Difficult
問題
I had an issue with intermittent muting of the phone when mute was on. After reading the guide and responses, I decided to give it a try.
修理
The repair went great! Photos were very helpful and gave me the necessary help to replace the button.
My issue was actually due to a cracked housing that holds the mute switch on the inside of the phone, probably damaged in a drop. The housing sheared in half and caused a mis-alignement of the external switch ($4.95 part) and the internal mechanism. After installing the new part, aligning the internal switch, and reassembling it works perfectly.
アドバイス
A few pieces that help you when working:
1) A mechanics magnetic bowl. You can pick them up at home depot for around $10 and work great for holding your screws. It reduces the chance of knocking them off of the table.
2) A screw driver magnetizer. It will help greatly when trying to align the small screws.
3) Definitely get the spudger and suction cup from fixit. A must have for undoing the connections and removing the screen.
Spudgerの画像
Spudger
$3.99
Suction Handleの画像
Suction Handle
$2.95
« 全てのストーリーへ戻る
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 12
今までの合計 184
