メインコンテンツにスキップ
Appleの消費者向け人気ラインのMacBook Airの修理ガイド
4824回答 すべてを表示
Re-connecting fan ribbon cable
I am trying to install a new fan but the ribbon cable is so small and flexible, I can't insert it into the ZIF socket.
Any suggestions?
Thanks
Update (08/27/2018)
I tried to do this and ended up breaking the latch while trying to pull the ribbon cable through the opening. Not happy about the result, although I think I have found a work-around
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Sorry to hear you have broken the latch.
You’ll need to get a new base connector and carefully snap it out and replace your broken latch unless you broke the connector body side in which case you’ll need to get some one with good micro soldering skills to replace the full connector.
Haven’t had any luck with work-arounds - Sorry
さんによる
コメントを追加
1 件の回答
ベストアンサー
Get some electrical tape and cut it down the the width of the ribbon cable fold over one end to create a pull tab. Now place the tape onto the ribbon to give your self something to pull either in or out as needed. Then you can peel off the tape.
Don't forget the unlatch the connector first!
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Close the latch after the cable is fully inserted to lock it in place.
さんによる
コメントを追加
回答を追加する
Steve B さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 21
今までの合計 756
