メインコンテンツにスキップ
Remplacement des bandes adhésives d'un iMac Intel 27" EMC 2546
ご注意:あなたは前提となるガイドを編集しています。あなたが行なう変更は、この手順を含むガイド全体に反映されます。
英語
フランス語
手順 16を翻訳中
手順16
iMac Intel 27" EMC 2546 Adhesive Strips Replacement: 手順 0、 2の画像 1 iMac Intel 27" EMC 2546 Adhesive Strips Replacement: 手順 0、 2の画像 2
  • Verify that your iMac is turned off and unplugged from power before you continue.
  • After confirming that your iMac functions properly, disconnect the display cables and carefully lean the display forward.
  • Remove the film from the 15 strip by reaching in from above and pulling the tab straight up from the bottom edge of the display.
Surtout ne pas abaisser complètement l'écran dans cette étape ; il restent encore deux câbles à attacher. Une fois que vous avez fixé l'écran vers le bas, vous ne serez pas en mesure de le soulever à nouveau sans endommager l'adhésif.
Poser le bord inférieur du verre de l'écran contre le haut du joint inférieur. Assurez-vous d'aligner les bords de l'écran avec les bords du boîtier arrière.
-[* icon_caution] ***Do not ***fully lower the display in this step; there are still two cables that must be attached. Once you've set the display down, you won't be able to lift it again without damaging the adhesive.
-[* black] Lay the bottom edge of the display glass against the top of the lower bezel. Be sure to align the edges of the display with the edges of the rear case.
+[* icon_caution] Verify that your iMac is turned off and unplugged from power before you continue.
+[* black] After confirming that your iMac functions properly, disconnect the display cables and carefully lean the display forward.
+[* black] Remove the film from the 15 strip by reaching in from above and pulling the tab straight up from the bottom edge of the display.
クリエイティブコモンズのオープンソース著作権のもと、あなたの投稿は著作権の対象となります
