メインコンテンツにスキップ
Remplacement des bandes adhésives d'un iMac Intel 27" EMC 2546
ご注意:あなたは前提となるガイドを編集しています。あなたが行なう変更は、この手順を含むガイド全体に反映されます。
英語
フランス語
手順 15を翻訳中
手順15
iMac Intel 27" EMC 2546 Adhesive Strips Replacement: 手順 0、 2の画像 1 iMac Intel 27" EMC 2546 Adhesive Strips Replacement: 手順 0、 2の画像 2
  • Set the display back on the iMac's rear enclosure.
  • At this time, plug in your iMac, power it on, and test your repair before moving on to actually sealing up the computer. Be sure to check for full functionality of any hardware you removed or disconnected.
  • When you are finished, shut the iMac down and unplug the power cord before you continue.
Décollez et enlevez les protections restantes de toutes les bandes autour de l´encadrement.
-[* black] Peel up and remove the remaining backings from all of the strips around the frame.
+[* black] Set the display back on the iMac's rear enclosure.
+[* icon_note] At this time, plug in your iMac, power it on, and test your repair before moving on to actually sealing up the computer. Be sure to check for full functionality of any hardware you removed or disconnected.
+[* icon_caution] When you are finished, shut the iMac down and ***unplug the power cord*** before you continue.
クリエイティブコモンズのオープンソース著作権のもと、あなたの投稿は著作権の対象となります
