メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iodyne Pro Data Memory Module Replacement
必要な工具と部品
  1. iodyne Pro Data Memory Module Replacement, Remove Service Panel Screws: 手順 1、 1の画像 1
    この手順で使用する道具:
    Anti-Static Wrist Strap
    $7.95
    • Make sure Pro Data is disconnected from power and Thunderbolt, then set it upside down on an anti-static mat or flat surface with appropriate protection from electrostatic discharge, such as an anti-static wrist strap.
    • Using a #2 Phillips screwdriver, remove the two screws securing the service panel into place.
    FixBotに聞いてみる
    コメントを追加
  2. iodyne Pro Data Memory Module Replacement, Dislodge Service Panel: 手順 2、 3の画像 1 iodyne Pro Data Memory Module Replacement, Dislodge Service Panel: 手順 2、 3の画像 2 iodyne Pro Data Memory Module Replacement, Dislodge Service Panel: 手順 2、 3の画像 3
    • Turn Pro Data over to the top side. Grip the chassis from the long sides, and push the service panel slightly down and away from the vent. It should slide about 5mm or .2" before stopping.
    • Grab the service panel from the left edge and lift up about 30°, dislodging its tabs from the vent, and remove to reveal the chassis interior.
    FixBotに聞いてみる
    コメントを追加
  3. iodyne Pro Data Memory Module Replacement, Remove screw covers: 手順 3、 1の画像 1
    • Remove the four screw covers and place them upside down on a clean surface for later application during reassembly.
    FixBotに聞いてみる
    コメントを追加
  4. iodyne Pro Data Memory Module Replacement, Unfasten vent panel: 手順 4、 2の画像 1 iodyne Pro Data Memory Module Replacement, Unfasten vent panel: 手順 4、 2の画像 2
    • Unscrew the four T4 Torx screws revealed beneath the rubber feet.
    • Grab Pro Data around the vent panel to prevent it from dropping, and flip the chassis right side up.
    FixBotに聞いてみる
    コメントを追加
  5. iodyne Pro Data Memory Module Replacement, Remove vent panel: 手順 5、 2の画像 1 iodyne Pro Data Memory Module Replacement, Remove vent panel: 手順 5、 2の画像 2
    • Remove the vent panel by lifting directly up to dislodge it from the brace.
    FixBotに聞いてみる
    コメントを追加
  6. iodyne Pro Data Memory Module Replacement, Unfasten heatsink: 手順 6、 2の画像 1 iodyne Pro Data Memory Module Replacement, Unfasten heatsink: 手順 6、 2の画像 2
    この手順で使用する道具:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    • Incrementally unfasten the two sprung screws using a 3mm flathead screwdriver, being careful not to let the driver slip out and damage other motherboard components. These screws are retained with the heatsink as it removed.
    FixBotに聞いてみる
    コメントを追加
  7. iodyne Pro Data Memory Module Replacement, Remove heatsink: 手順 7、 2の画像 1 iodyne Pro Data Memory Module Replacement, Remove heatsink: 手順 7、 2の画像 2
    • Gently remove the heatsink from its socket by lifting directly up, revealing the Memory module underneath.
    FixBotに聞いてみる
    コメントを追加
  8. iodyne Pro Data Memory Module Replacement, Remove heatsink thermal pad: 手順 8、 1の画像 1
    • Using a spudger or non-metal tool, remove the thermal pad from the heatsink. Replace this with the 1.5mm thermal pad provided with the replacement Memory module kit.
    FixBotに聞いてみる
    コメントを追加
  9. iodyne Pro Data Memory Module Replacement, Remove Memory module: 手順 9、 2の画像 1 iodyne Pro Data Memory Module Replacement, Remove Memory module: 手順 9、 2の画像 2
    • Push the two retaining clips away from the Memory module to allow it to spring up at an angle.
    • Carefully remove the Memory module by gripping both short sides and pulling away from its socket at an angle. This will reveal a second thermal pad attached to the motherboard.
    FixBotに聞いてみる
    コメントを追加
  10. iodyne Pro Data Memory Module Replacement, Remove motherboard thermal pad: 手順 10、 2の画像 1 iodyne Pro Data Memory Module Replacement, Remove motherboard thermal pad: 手順 10、 2の画像 2
    • Using a spudger or non-metal tool, remove the thermal pad from the motherboard. Replace this with the 2mm thermal pad provided with the replacement Memory module kit.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
2人の作成者と共同で作成されました。
iodyne
メンバー登録日: 01/01/22
462 ポイント
4のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 25
今までの合計 464
