はじめに
This guide will show you how to open your tablet in order to view/repair its inner parts! Also, if you have a cracked or broken rear panel this guide will aid you in its replacement. One must take extreme care when removing the rear panel from the device because impatient prying may cause your screen or rear panel to break.
必要な工具と部品
Use the plastic opening tool to release the clips holding the rear panel of the device onto the front section.
Continue around the entire device until all of the clips have been released.
ある他の人がこのガイドを完成しました。
