メインコンテンツにスキップ
iRobot Roomba 890 Bumper Sensors Replacement
必要な工具と部品
  1. iRobot Roomba 890 Bumper Sensors Replacement, Bumper/Cliff Sensors: 手順 1、 2の画像 1 iRobot Roomba 890 Bumper Sensors Replacement, Bumper/Cliff Sensors: 手順 1、 2の画像 2
    • Use a Phillips #2 screwdriver to remove the 7.7 mm screw securing the side brush-head.
    • Lift off the yellow brush head.
  2. iRobot Roomba 890 Bumper Sensors Replacement: 手順 2、 1の画像 1
    • Place the Roomba with its bottom facing toward you.
    • Use a Phillips #2 screwdriver to remove the four 11 mm screws.
  3. iRobot Roomba 890 Bumper Sensors Replacement: 手順 3、 1の画像 1
    • Remove the battery plate.
    • Remove the battery by pulling directly up on the grey pull tabs.
  4. iRobot Roomba 890 Bumper Sensors Replacement: 手順 4、 1の画像 1
    • Lift off the baseplate.
  5. iRobot Roomba 890 Bumper Sensors Replacement: 手順 5、 2の画像 1 iRobot Roomba 890 Bumper Sensors Replacement: 手順 5、 2の画像 2
    • Turn the Roomba face up.
    • Press the release button on the top side of the Roomba and pull the dustbin straight out.
  6. iRobot Roomba 890 Bumper Sensors Replacement: 手順 6、 2の画像 1 iRobot Roomba 890 Bumper Sensors Replacement: 手順 6、 2の画像 2
    • Use a Phillips #2 screwdriver to remove the ten 9.3 mm screws.
    • Remove the bumper retainer ring.
    • The bumper will now only be attached by the IR sensors' wires; be careful not to damage them.
  7. iRobot Roomba 890 Bumper Sensors Replacement: 手順 7、 1の画像 1
    • Use a Phillips #2 screwdriver to remove the two 7.5 mm IR Sensor screws.
    • Remove the IR Sensor assembly.
  8. iRobot Roomba 890 Bumper Sensors Replacement: 手順 8、 2の画像 1 iRobot Roomba 890 Bumper Sensors Replacement: 手順 8、 2の画像 2
    • Use the iFixit opening tool to remove the retaining band.
    • Use the iFixit opening tool to remove the faceplate.
    • Pry up slowly around the edges as to not damage the plastic components.
  9. iRobot Roomba 890 Bumper Sensors Replacement: 手順 9、 3の画像 1 iRobot Roomba 890 Bumper Sensors Replacement: 手順 9、 3の画像 2 iRobot Roomba 890 Bumper Sensors Replacement: 手順 9、 3の画像 3
    • Use a Phillips #1 screwdriver to remove the two 9.5 mm handle screws.
    • Use a Phillips #1 screwdriver to remove the fourteen 9.5 mm top plate screws.
    • Remove the top plastic plate.
  10. iRobot Roomba 890 Bumper Sensors Replacement: 手順 10、 2の画像 1 iRobot Roomba 890 Bumper Sensors Replacement: 手順 10、 2の画像 2
    • Disconnect the bumper/cliff sensor harness from motherboard.
    • Do not pull on the wires; instead pull on the white connector. Sometimes it is necessary to gently "walk" the connector from side to side to loosen it. Never pull at an angle.
  11. iRobot Roomba 890 Bumper Sensors Replacement: 手順 11、 1の画像 1
    • Use a Phillips #1 screwdriver to remove the four 9.3 mm bumper sensor screws.
  12. iRobot Roomba 890 Bumper Sensors Replacement: 手順 12、 2の画像 1 iRobot Roomba 890 Bumper Sensors Replacement: 手順 12、 2の画像 2
    この手順で使用する道具:
    購入する
    • Use blunt nose tweezers to remove the four cliff sensors.
    • Grip the IR sensors between the sensor and the Roomba chassis, then push on the sensors in an upward motion from the bottom of the sensor to remove them.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Devin Steiblin
メンバー登録日: 03/28/22
442 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 1-3, Petersen Spring 2022 UMass Dartmouth, Team 1-3, Petersen Spring 2022人のメンバー
UMASSD-PETERSEN-S22S1G3
3 メンバー
7のガイドは作成済み
コメント 1 件
for step 12: just make sure to push in the IR cliff sensor towards the roomba and they should pop out really easily.
bob bob - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 20
今までの合計 864
