メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iRobot Braava 320 Wheel Replacement
必要な工具と部品
    1. iRobot Braava 320 Wheel Replacement, Battery: 手順 1、 1の画像 1
      • Flip your device over and locate the battery cover.
      • The battery cover is located in the center of the device in between both wheels.
      FixBotに聞いてみる
      コメントを追加
    2. iRobot Braava 320 Wheel Replacement: 手順 2、 1の画像 1
      • Using a Flathead #4 screwdriver, gently turn the 12mm screw that holds the battery cover in.
      • The screw does not remove, it stays attached to the cover.
      FixBotに聞いてみる
      コメントを追加
    3. iRobot Braava 320 Wheel Replacement: 手順 3、 2の画像 1 iRobot Braava 320 Wheel Replacement: 手順 3、 2の画像 2
      • Gently remove the battery from the tray and disconnect the battery cable.
      • To remove the battery, pull it straight up. To disconnect the cable, gently pull it straight out of the connector.
      • To reinstall the cable, hold it near the end and gently push it in the connector.
      FixBotに聞いてみる
      コメントを追加
    1. iRobot Braava 320 Wheel Replacement, Body Shell and Control Panel: 手順 4、 1の画像 1
      • With the battery removed, rotate your device so the front of it is facing you.
      • Remove the four 10mm Phillips #2 screws that attach the shell.
      FixBotに聞いてみる
      コメントを追加
    2. iRobot Braava 320 Wheel Replacement: 手順 5、 2の画像 1 iRobot Braava 320 Wheel Replacement: 手順 5、 2の画像 2
      • Using both hands, hold the device together while you flip it over.
      • Starting from the front, gently lift up the shell and slowly tilt back until it is fully removed.
      FixBotに聞いてみる
      コメントを追加
    1. iRobot Braava 320 Wheel Replacement, Wheel: 手順 6、 3の画像 1 iRobot Braava 320 Wheel Replacement, Wheel: 手順 6、 3の画像 2 iRobot Braava 320 Wheel Replacement, Wheel: 手順 6、 3の画像 3
      • To remove the wheel covers, hold the wheel in place with one hand while turning the cover clock-wise with the other.
      • The cover should come off as soon as you hear a 'click' sound.
      • When replacing the cover, align the notches on the cover just to the right of the ones on the wheel.
      FixBotに聞いてみる
      コメントを追加
    2. iRobot Braava 320 Wheel Replacement: 手順 7、 3の画像 1 iRobot Braava 320 Wheel Replacement: 手順 7、 3の画像 2 iRobot Braava 320 Wheel Replacement: 手順 7、 3の画像 3
      • Using a small Flathead screwdriver, remove the small black clip in the center of the wheel.
      • To ensure the clip does not fly off, place your hand over the wheel to cover it as you remove the clip.
      FixBotに聞いてみる
      コメントを追加
    3. iRobot Braava 320 Wheel Replacement: 手順 8、 3の画像 1 iRobot Braava 320 Wheel Replacement: 手順 8、 3の画像 2 iRobot Braava 320 Wheel Replacement: 手順 8、 3の画像 3
      • Once the small black clip is removed, the wheel should come off by gently pulling on it.
      • Be careful not to lose the two small chrome pieces located on each side of the wheel.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
14 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Ruven Tapia-Vargas
メンバー登録日: 02/28/17
409 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team S1-G3, Nance Spring 2017 USF Tampa, Team S1-G3, Nance Spring 2017人のメンバー
USFT-NANCE-S17S1G3
4 メンバー
20のガイドは作成済み
1件のガイドコメント
O roteiro descritivo para a troca das rodas do Braava foi muito útil. Obrigada!
Vanilda Chueiri - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 33
今までの合計 10,720
