メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iPod Touch 4th Generation Home Button Replacement
必要な工具と部品
  1. iPod Touch 4th Generation Home Button Replacement, Home Button: 手順 1、 1の画像 1
    • The iPod Touch 4th Generation front panel is attached to the rear case by adhesive. The use of a heat gun to soften the adhesive is highly recommended.
    • With the heat gun set on "low", begin heating the lower portion of the Touch near the home button.
    • It is suggested to heat the desired portion in a circular motion pattern to evenly dissipate the amount of heat throughout the device.
    FixBotに聞いてみる
    コメントを追加
  2. iPod Touch 4th Generation Home Button Replacement: 手順 2、 2の画像 1 iPod Touch 4th Generation Home Button Replacement: 手順 2、 2の画像 2
    • Beware, as the Touch will be very hot. It may be helpful to hold it with a towel while prying.
    • Insert the edge of an iPod opening tool between the front glass panel and the black plastic bezel near the home button.
    • Do not try to pry between the black plastic bezel and the steel rear case.
    • Pry the bottom edge of the front panel upward, being careful not to bend the glass excessively.
    • If it is too difficult to pry up the front panel assembly, reheat it and try again.
    FixBotに聞いてみる
    コメントを追加
  3. iPod Touch 4th Generation Home Button Replacement: 手順 3、 1の画像 1
    • When there is enough room to grab the bottom edge of the front panel, lift the front panel away from the body of the Touch to peel up the adhesive along its left and right edges.
    • If the adhesive is too difficult to separate, use a heat gun to soften it before proceeding.
    FixBotに聞いてみる
    コメントを追加
  4. iPod Touch 4th Generation Home Button Replacement: 手順 4、 2の画像 1 iPod Touch 4th Generation Home Button Replacement: 手順 4、 2の画像 2
    • Due to the construction of the Touch, the digitizer cable cannot be disconnected until the logic board is removed. Use extreme caution when handling the front panel assembly, as it is attached to the rest of the Touch by the very delicate digitizer cable.
    • The display data cable is very short and is connected to the logic board near the top of the front panel assembly. If it does not become disconnected while freeing the top edge of the front panel assembly, be sure to disconnect it with a plastic opening tool before rotating the front panel assembly out of the Touch.
    • Carefully pull the top of the front panel assembly away from the adhesive holding it to the Touch, minding the short digitizer cable connecting the two components.
    FixBotに聞いてみる
    コメントを追加
  5. iPod Touch 4th Generation Home Button Replacement: 手順 5、 3の画像 1 iPod Touch 4th Generation Home Button Replacement: 手順 5、 3の画像 2 iPod Touch 4th Generation Home Button Replacement: 手順 5、 3の画像 3
    • Being careful not to rip any ribbon cables still connecting the two halves of the device, lay the device out so that you can access the back side of the display assembly.
    • Insert a plastic opening tool under the rubber holding the home button in place.
    • Slide the tool around the perimeter of the button, prying up as you go.
    • Lift the home button out of the device.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
69 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Jake Devincenzi
メンバー登録日: 04/18/11
119,294 ポイント
57のガイドは作成済み
11件のガイドコメント
what about replaceing it not take it off
sahar - 返信 共有
"To reassemble your device, follow these instructions in reverse order."
Nicholas Loudermilk - 返信 共有
So Nice. Its Fully help
Aamir Mushtaq - 返信 共有
can you make professional step by step tutorial on how to put the touch back together like the one you made to take it apart ?
lucy jones - 返信 共有
If you follow the guide from the bottom to the top, you can reassemble the device. If you disassembled the phone farther than the Home Button guide shows, go back to the device page and follow the guide that matches your device.
Sam Goldheart - 返信 共有
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 26
過去 30 日: 137
今までの合計 91,584
