メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iPhone Camera Repair
必要な工具と部品
ビデオの概要
  1. iPhone Camera Repair, main camera: 手順 1、 2の画像 1 iPhone Camera Repair, main camera: 手順 1、 2の画像 2
    • Today, REWA LAB will share with you a repair case of an iPhone camera and walk you through some knowledge of iPhone camera repair.
    • Open the phone camera. When taking photos with the wide-angle camera, cracks appear. The ultra-wide camera works fine. We can judge that the optical filter of the wide-angle camera is damaged.
    FixBotに聞いてみる
    コメントを追加
  2. iPhone Camera Repair: 手順 2、 3の画像 1 iPhone Camera Repair: 手順 2、 3の画像 2 iPhone Camera Repair: 手順 2、 3の画像 3
    • We can judge that the optical filter of the wide-angle camera is damaged. Then we disassemble the phone and try to repair the camera. First of all, put the camera on the specialized Heating Platform at 100 °C.
    • When the temperature reaches 100 °C, remove black adhesive around the camera with a Sculpture Knife. Then pry up the wide-angle camera.
    • Attach the camera to the specialized holder. Before repair, apply protection tape to the camera.
    FixBotに聞いてみる
    コメントを追加
  3. iPhone Camera Repair: 手順 3、 3の画像 1 iPhone Camera Repair: 手順 3、 3の画像 2 iPhone Camera Repair: 手順 3、 3の画像 3
    この手順で使用する道具:
    • Separate the camera edges with a Sculpture Knife. Next, remove the metal cover with Hot Air Gun at 120 °C.
    • Keep heating with Hot Air Gun at 120 °C. Remove black adhesive with Tweezers. Apply some Paste Flux.
    • Separate the motor from the CMOS with ultrathin Soldering Iron at 380 °C
    FixBotに聞いてみる
    コメントを追加
  4. iPhone Camera Repair: 手順 4、 2の画像 1 iPhone Camera Repair: 手順 4、 2の画像 2
    • It can be seen that the optical filter is broken while the motor and blue lens are good. If the motor is damaged, the camera will fail to focus or shake. A motor replacement can help you solve the problem.
    • The middle part of the motor is the blue lens. If the blue lens is damaged, the camera will become blurry. The solution is to replace the blue lens.
    • Then we replace the cracked optical filter with a new one.
    FixBotに聞いてみる
    コメントを追加
  5. iPhone Camera Repair: 手順 5、 3の画像 1 iPhone Camera Repair: 手順 5、 3の画像 2 iPhone Camera Repair: 手順 5、 3の画像 3
    • Apply some UV adhesive to the broken optical filter.
    • Put the new optical filter in position.
    • Solidify with a UV Lamp.
    FixBotに聞いてみる
    コメントを追加
  6. iPhone Camera Repair: 手順 6、 3の画像 1 iPhone Camera Repair: 手順 6、 3の画像 2 iPhone Camera Repair: 手順 6、 3の画像 3
    • Remove side adhesive with Hot Air Gun.
    • Then push the cracked optical filter out with the specialized holder.
    • Remove residual shards and black adhesive with Hot Air Gun.
    FixBotに聞いてみる
    コメントを追加
  7. iPhone Camera Repair: 手順 7、 3の画像 1 iPhone Camera Repair: 手順 7、 3の画像 2 iPhone Camera Repair: 手順 7、 3の画像 3
    • Then remove dust spots with a specialized swab. Please be extremely careful not to damage the CMOS during operation. If the CMOS is damaged, the camera will be unrepairable.
    • Then apply some UV adhesive and a new optical filter. Solidify with UV Lamp.
    FixBotに聞いてみる
    コメントを追加
  8. iPhone Camera Repair: 手順 8、 3の画像 1 iPhone Camera Repair: 手順 8、 3の画像 2 iPhone Camera Repair: 手順 8、 3の画像 3
    • Then we assemble the camera. Apply some Paste Flux around the motor. Solder the motor with the CMOS with Soldering Iron. Clean the camera with alcohol.
    • Next, we install the wide-angle camera for testing. The camera works fine. Apply B7000 to fix the wide-angle camera. That’s all for the optical filter replacement of iPhone camera.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
9 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
REWA
メンバー登録日: 11/24/20
19,375 ポイント
55のガイドは作成済み
2件のガイドコメント
Good job! But, the cost of labor and material is not economical. It is still wise to buy the whole camera module as a replacement. Easier and more practical.
On the other hand, if the viewer opted to do the filter replacement, this is a great reference since Rewa is a reputable company. Thank you for sharing this useful guide.
Jojo - 返信 共有
Incrível! Parabéns!!
Daan.ll - 返信 共有
コメントを追加
統計データ:
過去 24時間: 28
過去 7 日: 154
過去 30 日: 841
今までの合計 31,675
