メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iPhone 3G Display Assembly Replacement
必要な工具と部品
ビデオの概要
  1. iPhone 3G Display Assembly Replacement, Broken Glass: 手順 1、 3の画像 1 iPhone 3G Display Assembly Replacement, Broken Glass: 手順 1、 3の画像 2 iPhone 3G Display Assembly Replacement, Broken Glass: 手順 1、 3の画像 3
    • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    FixBotに聞いてみる
    コメントを追加
  2. iPhone 3G Display Assembly Replacement, Display Assembly: 手順 2、 1の画像 1
    • Remove the two Phillips #00 screws from the dock-connector end of the iPhone.
    FixBotに聞いてみる
    コメントを追加
  3. iPhone 3G Display Assembly Replacement: 手順 3、 1の画像 1
    • Remove the metal handle from the suction cup. It's easier and safer to grip the suction cup's base instead of the metal handle.
    • Be very careful when opening the iPhone so that the cables under the display are not severed.
    • There is a rubber gasket between the silver front bezel and black display assembly. A bit of force is required in this step to separate the iPhone's display assembly.
    • Use a small suction cup near the Home button to gently pull up the bottom portion of the iPhone's display assembly.
    • If the display assembly is too damaged to allow the suction cup to adhere, tape with a strong adhesive such as duct tape may be used.
    FixBotに聞いてみる
    コメントを追加
  4. iPhone 3G Display Assembly Replacement: 手順 4、 1の画像 1
    • The display assembly is still connected to the iPhone by several cables, so don't try to remove it entirely just yet.
    • Rotate the display assembly up until it is at an angle of approximately 45 degrees.
    FixBotに聞いてみる
    コメントを追加
  5. iPhone 3G Display Assembly Replacement: 手順 5、 1の画像 1
    • Continue to hold the display assembly with one hand, and use your other hand and a spudger to disconnect the black ribbon cable labeled "1."
    FixBotに聞いてみる
    コメントを追加
  6. iPhone 3G Display Assembly Replacement: 手順 6、 1の画像 1
    • Rotate the display assembly up until it is roughly vertical. This will allow easier access for disconnecting the remaining cables.
    • Use a spudger to disconnect the black ribbon cable labeled "2."
    FixBotに聞いてみる
    コメントを追加
  7. iPhone 3G Display Assembly Replacement: 手順 7、 1の画像 1
    • Use a spudger to flip up the black plastic tab holding the remaining ribbon cable in place. The black will rotate up 90 degrees, releasing the ribbon cable.
    • The tab is very fragile, so be careful when flipping it up to unlock the cable and down to lock the cable.
    • The plastic tab may be white (instead of black) on some iPhone models.
    • Slide the ribbon cable out of its connector, and remove the display assembly from the iPhone.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
229 の人々がこのガイドを完成させました。
作成者
13人の作成者と共同で作成されました。
steve
6,690 ポイント
1ガイドが承認済み
1件のガイドコメント
i went through the whole process, but my home button does not work anymore. it was fine when I started - its it possible, that one ribbon is not fully attached ore is there any other solution? Thanks for any advice!
Jakob
JakobBartke - 返信 共有
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 21
過去 30 日: 94
今までの合計 305,348
