メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iPhone 1st Generation Display Assembly Replacement
必要な工具と部品
  1. iPhone 1st Generation Display Assembly Replacement, SIM Card: 手順 1、 1の画像 1
    • Insert a SIM card eject tool or paper clip into the hole next to the headphone jack.
    • Press down on the paper clip until the SIM card tray pops out.
    FixBotに聞いてみる
    コメントを追加
  2. iPhone 1st Generation Display Assembly Replacement: 手順 2、 1の画像 1
    • Grasp the SIM card tray and slide it out of the iPhone.
    FixBotに聞いてみる
    コメントを追加
  3. iPhone 1st Generation Display Assembly Replacement, Antenna Cover: 手順 3、 1の画像 1
    • This image shows the two tabs and two catches located on the underside of the antenna cover. The two tabs at the top of the image must be pushed towards the black cover to release them.
    FixBotに聞いてみる
    コメントを追加
  4. iPhone 1st Generation Display Assembly Replacement: 手順 4、 1の画像 1
    • Be sure to slide the metal spudger between the dock connector and the antenna cover, and not into the dock connector itself.
    • Insert a metal spudger into the slot between the dock connector and the antenna cover. Gently pry up near the two tabs to create a small gap between the antenna cover and the silver front bezel.
    FixBotに聞いてみる
    コメントを追加
  5. iPhone 1st Generation Display Assembly Replacement: 手順 5、 1の画像 1
    • Insert an iPod opening tool in the gap between the antenna cover and the front bezel. The wedge of the tool should be pointing towards the antenna cover. Slide the tool around the corner and up until you reach the metal backing.
    • Repeat the same procedure on the other side of the dock connector.
    FixBotに聞いてみる
    コメントを追加
  6. iPhone 1st Generation Display Assembly Replacement: 手順 6、 1の画像 1
    • Grasp the antenna cover on either side and slide it up and away from the iPhone. This requires some force. If it does not come free, ensure that the antenna cover is lifted up enough to free the catches.
    FixBotに聞いてみる
    コメントを追加
  7. iPhone 1st Generation Display Assembly Replacement, Case: 手順 7、 1の画像 1
    • Remove the three Phillips #00 screws securing the rear panel to the iPhone.
    FixBotに聞いてみる
    コメントを追加
  8. iPhone 1st Generation Display Assembly Replacement: 手順 8、 1の画像 1
    • Getting the iPhone open is a challenging feat, so don't get discouraged. Take a deep breath and make sure you have plenty of time to get the job done.
    • The small square hole is the location to insert the dental pick in the next step.
    FixBotに聞いてみる
    コメントを追加
  9. iPhone 1st Generation Display Assembly Replacement: 手順 9、 1の画像 1
    • Start removing the rear panel on the side with the buttons.
    • Slide the dental pick completely into the square hole. You may need to wiggle the tool and apply a good amount of force to get it to go all the way.
    FixBotに聞いてみる
    コメントを追加
  10. iPhone 1st Generation Display Assembly Replacement: 手順 10、 1の画像 1
    • Pry up the rear panel by pulling the dental pick counterclockwise in a quick motion. Apply force perpendicular to the plane of the display assembly. You may be afraid to go fast, but going slowly is more likely to bend the case.
    FixBotに聞いてみる
    コメントを追加
  11. iPhone 1st Generation Display Assembly Replacement: 手順 11、 1の画像 1
    • Use a spudger to free the rear panel from the iPhone along the corner and top.
    FixBotに聞いてみる
    コメントを追加
  12. iPhone 1st Generation Display Assembly Replacement: 手順 12、 1の画像 1
    • Repeat the same procedure on the other side of the iPhone. Slide the dental pick completely into the square hole. You may need to wiggle the tool and apply a good amount of force to get it to go all the way.
    FixBotに聞いてみる
    コメントを追加
  13. iPhone 1st Generation Display Assembly Replacement: 手順 13、 1の画像 1
    • Pry up the rear panel by pulling the dental pick clockwise in a quick motion. Apply force perpendicular to the plane of the display assembly. You may be afraid to go fast, but going slowly is more likely to bend the case.
    • The rear panel is still attached to the iPhone by the headphone jack cable, so don't entirely remove the rear panel from the iPhone just yet.
    FixBotに聞いてみる
    コメントを追加
  14. iPhone 1st Generation Display Assembly Replacement: 手順 14、 1の画像 1
    • Make sure the phone is off before disconnecting the headphone jack cable.
    • Use a spudger to disconnect the headphone jack cable from the logic board.
    FixBotに聞いてみる
    コメントを追加
  15. iPhone 1st Generation Display Assembly Replacement, Display Assembly: 手順 15、 1の画像 1
    • Peel up the orange tape securing the white antenna cable to the side of the iPhone.
    FixBotに聞いてみる
    コメントを追加
  16. iPhone 1st Generation Display Assembly Replacement: 手順 16、 1の画像 1
    • Use a spudger to disconnect the two antenna cables from the communications board. Apple used a small dab of glue on these connections, which may make removing the antenna connections harder.
    FixBotに聞いてみる
    コメントを追加
  17. iPhone 1st Generation Display Assembly Replacement: 手順 17、 1の画像 1
    • Remove the following 3 screws:
    • One Phillips #00 screw securing the logic board to the iPhone near the camera.
    • Two Phillips #00 screws, one on either corner of the logic board.
    FixBotに聞いてみる
    コメントを追加
  18. iPhone 1st Generation Display Assembly Replacement: 手順 18、 1の画像 1
    • Use a spudger to disconnect the camera connector.
    • Lift the camera out of the iPhone.
    FixBotに聞いてみる
    コメントを追加
  19. iPhone 1st Generation Display Assembly Replacement: 手順 19、 1の画像 1
    • Working from the edge opposite the battery connectors, insert a spudger between the battery and the plastic frame and pry up on the battery. It is attached to the casing with an adhesive, but should slowly come free.
    • Leave the battery resting slightly out of its housing, but be sure not to put too much pressure on the battery wires as the solder joints break easily.
    FixBotに聞いてみる
    コメントを追加
  20. iPhone 1st Generation Display Assembly Replacement: 手順 20、 1の画像 1
    • Slide a spudger beneath the logic board on the side opposite the battery connector and pry up slightly. Don't lift up too far, because there are still four attached connectors on the bottom of the logic board.
    FixBotに聞いてみる
    コメントを追加
  21. iPhone 1st Generation Display Assembly Replacement: 手順 21、 1の画像 1
    • In a similar manner, slide a spudger beneath the logic board where the camera was. Again, don't lift up too far yet as there are still four attached connectors on the bottom of the logic board.
    FixBotに聞いてみる
    コメントを追加
  22. iPhone 1st Generation Display Assembly Replacement: 手順 22、 1の画像 1
    • Lift up the logic board slightly and slide a spudger beneath the logic board to disconnect the display ribbon cable.
    • After freeing the first connector, slide the spudger further towards the battery and the center of the iPhone to disconnect the speaker connector.
    FixBotに聞いてみる
    コメントを追加
  23. iPhone 1st Generation Display Assembly Replacement: 手順 23、 1の画像 1
    • Go to the other side of the logic board and use a spudger to disconnect the touch sensor cable on the under side of the logic board.
    FixBotに聞いてみる
    コメントを追加
  24. iPhone 1st Generation Display Assembly Replacement: 手順 24、 1の画像 1
    • Slide a spudger beneath the black locking bar and pry up to rotate the bar 90 degrees (the bar is already rotated in the picture).
    FixBotに聞いてみる
    コメントを追加
  25. iPhone 1st Generation Display Assembly Replacement: 手順 25、 1の画像 1
    • Hold both the battery and the logic board assembly and slide both parts away from the orange antenna and out of the iPhone.
    FixBotに聞いてみる
    コメントを追加
  26. iPhone 1st Generation Display Assembly Replacement: 手順 26、 1の画像 1
    • Remove the three Phillips #00 screws securing the front bezel to the iPhone.
    FixBotに聞いてみる
    コメントを追加
  27. iPhone 1st Generation Display Assembly Replacement: 手順 27、 1の画像 1
    • Rotate the iPhone 90 degrees and remove the two Phillips #00 screws from the bottom of the iPhone.
    FixBotに聞いてみる
    コメントを追加
  28. iPhone 1st Generation Display Assembly Replacement: 手順 28、 1の画像 1
    • Rotate the iPhone 90 degrees and remove the three Phillips #00 screws from the side of the iPhone.
    FixBotに聞いてみる
    コメントを追加
  29. iPhone 1st Generation Display Assembly Replacement: 手順 29、 1の画像 1
    • Rotate the iPhone 90 degrees and remove the two Phillips #00 screws from the top of the iPhone.
    FixBotに聞いてみる
    コメントを追加
  30. iPhone 1st Generation Display Assembly Replacement: 手順 30、 1の画像 1
    • Lift the front bezel away from the iPhone.
    FixBotに聞いてみる
    コメントを追加
  31. iPhone 1st Generation Display Assembly Replacement: 手順 31、 1の画像 1
    • Display assembly remains.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
154 の人々がこのガイドを完成させました。
作成者
12人の作成者と共同で作成されました。
iRobot
メンバー登録日: 09/24/09
1 ポイント
636のガイドは作成済み
4件のガイドコメント
I'll second rafa74's comment: be VERY careful about putting too much stress on the TINY cable that connects the Home button to the rest of its assembly! I ripped mine as well. You have to slowly separate the Home button's plastic sub-assembly from the display module itself (with a kitchen knife, for example). Otherwise the moment you start parting the display module from the mid-board, you run the risk of tearing the Home button cable... it's far too easy.
ptfini - 返信 共有
This guide neglects to point out some very important things at the end of the removal process. For example, that the glass is glued to the phone, or which connectors have to come with the display assembly on the way out.
offscreenmodulation - 返信 共有
This is my first opening session and sounds great !!! Thanks I fix it
Xtophe Raillon - 返信 共有
I swapped motherboard + battery between 2 original iPhone models, but now on one the touchscreen won’t work even if the connector is attached. The flat looks PERFECT, that’s what bothers me the most, the connector looks also greet, same goes for the “slot” on the motherboard. What is going on? I needed to literarily detach the display assembly from the mid frame, tough, to also swap the 2 displays assemblies (long story). Do the touch for some reason won’t work until I put the bezel and all the screws? Thanks
Riccardo iDex - 返信 共有
コメントを追加
統計データ:
過去 24時間: 17
過去 7 日: 50
過去 30 日: 220
今までの合計 352,717
