はじめに
Removing the display requires cutting through the adhesive around the perimeter of the screen. After the adhesive is cut, it cannot be used to re-seal the display in place, so you'll need to apply a new set of adhesive strips.
This guide shows how to replace the adhesive strips for most 21.5” Intel iMacs. Some images in this guide use an older iMac, which has minor visual differences. These differences do not affect the repair procedure.
必要な工具と部品
With the hinge free to move, the iMac will be unbalanced and hard to work on. Place an iMac service wedge in the stand to stabilize the iMac.
If you are re-using your existing display, you must also remove the old adhesive from the back of the display.
Peel off the old strips of adhesive using tweezers or your fingers. Start at the bottom and peel upward towards the top of the device.
After all the old adhesive is removed, carefully clean off the adhesive residue with high-concentration isopropyl alcohol (90% or greater) and a lint-free cloth. Wipe in one direction, not back and forth.
Lay out the adhesives strips beforehand so you won't accidentally install a strip in the wrong place:
Strip 01 on the top left
Strip 02 on the top right
Strip 03 on the right vertical
Strip 4R on the bottom right, dark side facing up
Strip 4L on the bottom left, dark side facing up
Strip 05 on the left vertical
Start with strip 03, which goes on the right vertical side of the rear enclosure.
Grasp the blue tab and peel the short piece of backing off the back of the strip to expose a section of adhesive to attach to the enclosure.
Insert the tip of a spudger into the hole at the end of the strip where you just removed one layer of backing. Insert the spudger from the side that still has a layer of white backing on it.
With the spudger still poking through the hole in the adhesive strip, push the spudger tip into the corresponding hole in the frame of the iMac.
Using the hole and spudger to anchor the position of the adhesive strip, line the strip up against the right edge, gently pulling up against the spudger to ensure the strip is taut, and stick it onto the frame.
Work your way counter-clockwise around the perimeter of the iMac, adding three more adhesive strips in the same manner:
Grasp the red pull tab on strip 4R and pull to separate about 2 inches (5 cm) of white backing from the strip.
Align the adhesive strip to the bottom edge by positioning the microphone notch over the microphone hole.
If your iMac does not have a microphone hole, align the right end of the strip such that the L-bend sits next to the right vertical adhesive. The L-bend should not overlap the right vertical adhesive.
Once you have aligned the strip, carefully set the left exposed edge onto the iMac to secure the alignment.
After confirming that your iMac functions properly, disconnect the display cables and carefully lean the display forward.
Remove the film from the two bottom strips by reaching in from above with a pair of tweezers and pulling the blue tabs straight up from the bottom edge of the display.
Reconnect the display power and data cables for the final time.
Steady the display with one hand as you remove the protective film in the following steps, or rest it lightly against the iMac's enclosure.
63 の人々がこのガイドを完成させました。
7 件のコメント
Used this guide and the official iFixit strips and everything worked great, until about 6 months later when the screen fell out. I had cleaned off all dust and checked the screen 24 hours later as recommended. Is there anything I could have done better? When I reattach it with new strips I’m going to lay it upward with light pressure around the edges for 24 hours.
I’m sorry to hear that! If you can, please contact our customer support and give them some details on where the adhesive gave out. It may have been defective strips—they can get you sorted out if that’s the case!
In the final stage of removing the numbered tab, the blue tab for the lower portion of strip 3 cam off before revealing any of the white release film. Do you have any tips on how to remove it once it’s stuck everywhere else or is it a case of just leaving it.
Adam Court - 返信
Hey Adam! You can try inserting a needle or the point of a pair of tweezers underneath the white liner. You may be able to loosen the liner enough to grasp and remove it. Otherwise, if it's a small portion, I wouldn't worry too much about it.
