メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iMac G5 17" Model A1058 PRAM Battery Replacement
必要な工具と部品
    1. iMac G5 17" Model A1058 PRAM Battery Replacement, Rear Panel: 手順 1、 1の画像 1
      • Lay the iMac display-side down on a flat surface.
      • Loosen the three Phillips screws securing the rear panel to the iMac.
      • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
      FixBotに聞いてみる
      コメントを追加
    2. iMac G5 17" Model A1058 PRAM Battery Replacement: 手順 2、 3の画像 1 iMac G5 17" Model A1058 PRAM Battery Replacement: 手順 2、 3の画像 2 iMac G5 17" Model A1058 PRAM Battery Replacement: 手順 2、 3の画像 3
      • Lift the rear panel slightly from the bottom edge of the iMac.
      • Pull the rear panel toward yourself and remove it from the iMac.
      FixBotに聞いてみる
      コメントを追加
    1. iMac G5 17" Model A1058 PRAM Battery Replacement, AirPort Extreme: 手順 3、 1の画像 1
      • Lift the AirPort card slightly by its plastic tab and pull it straight away from its socket.
      • During reinstallation, insert the AirPort card such that the antenna side is nearest the center of the logic board.
      FixBotに聞いてみる
      コメントを追加
    2. iMac G5 17" Model A1058 PRAM Battery Replacement: 手順 4、 1の画像 1
      • Insert the flat end of a spudger between the body of the AirPort card and its antenna connector.
      • Push the spudger away from the AirPort card to disconnect the AirPort antenna.
      • When reassembling your iMac, be sure to insert the AirPort card the way it was before disassembly.
      FixBotに聞いてみる
      コメントを追加
    1. iMac G5 17" Model A1058 PRAM Battery Replacement, PRAM Battery: 手順 5、 1の画像 1
      • Remove the two 5.5 mm T6 Torx screws securing the AirPort bracket to the logic board.
      FixBotに聞いてみる
      コメントを追加
    2. iMac G5 17" Model A1058 PRAM Battery Replacement: 手順 6、 1の画像 1
      • Slightly lift the AirPort bracket off the logic board.
      • De-route the AirPort antenna through the slot in the AirPort bracket.
      FixBotに聞いてみる
      コメントを追加
    3. iMac G5 17" Model A1058 PRAM Battery Replacement: 手順 7、 1の画像 1
      • Slightly insert the tip of a spudger (or any other small wedge-shaped object) under the PRAM battery directly across from its retaining clip.
      • Do not bend the metal retaining clip up, as it is brittle and will break.
      • Use another spudger to slide the PRAM battery out from under its socket's retaining clip.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
10 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Walter Galan
710,597 ポイント
1,203のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 16
過去 30 日: 66
今までの合計 19,555
