はじめに
This guide instructs you to replace the screen in an iHome iPL8. The process includes using two sizes of screwdrivers.
必要な工具と部品
Turn the device over to access the bottom panel.
Locate the 6mm Phillips #2 screw under the label "unscrew to open door."
Keeping your device upside-down, locate the four 6mm Phillips #2 screws near each corner.
Remove the four 6mm Phillips #2 screws.
Look at the side of the device. You will see a green panel connecting to the black box by a white stripe.
Remove the four 2.5 mm Phillips #1 screws on the green panel.
Flip the green panel to reveal the front of the screen.
ある他の人がこのガイドを完成しました。
