はじめに
This guide instructs you to replace the lightning connector in an iHome iPL8. The process includes using two sizes of screwdrivers.
必要な工具と部品
Turn the device over to access the bottom panel.
Locate the 6mm Phillips #2 screw under the label "unscrew to open door."
Keeping your device upside-down, locate the four 6mm Phillips #2 screws near each corner.
Remove the four 6mm Phillips #2 screws.
3件のガイドコメント
where can I find the replacement lightning connector?
Greetings, did you ever find the connector replacement? I am asking so that I can purchase. Thank you in advance for your reply.
