メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iHome iH27B Power Connector Replacement
必要な工具と部品
    1. iHome iH27B Power Connector Replacement, Outer Case: 手順 1、 1の画像 1
      • Remove any iPod or apple music device connected to the iHome and unplug from any power source.
      • Flip the iHome so the speakers are laying on a flat surface, and you have the concealed battery areas facing you.
      FixBotに聞いてみる
      コメントを追加
    2. iHome iH27B Power Connector Replacement: 手順 2、 3の画像 1 iHome iH27B Power Connector Replacement: 手順 2、 3の画像 2 iHome iH27B Power Connector Replacement: 手順 2、 3の画像 3
      • Using your fingers, press down firmly on the plastic slide and push in the direction of the arrows shown above the word "Open" on the plastic.
      • Remove the plastic slide from its location and set it aside.
      • These plastic slides are not interchangeable, so make sure each goes back to its original location in reassembly.
      • Remove all 4 AA batteries by placing your fingernail at one end of the battery and applying force upwards until the battery is freed from its holder.
      • Insert your fingernail or a prying tool under the notch of the plastic slide that is protecting the watch battery.
      • Set the plastic covering and the watch battery aside.
      FixBotに聞いてみる
      コメントを追加
    3. iHome iH27B Power Connector Replacement: 手順 3、 1の画像 1
      • Remove the following screws:
      • Eight 10 mm using the Phillips #0 on the bottom of your device.
      • Cataloging each screw by size in plastic bags or separate places on a flat surface will make them easier to find when reassembling.
      FixBotに聞いてみる
      コメントを追加
    4. iHome iH27B Power Connector Replacement: 手順 4、 1の画像 1
      • Use your fingers or a plastic opening tool to carefully pry apart the plastic connections still connecting the base to the top.
      • Be careful not to pry too hard. Cracking the plastic connections could make reassembly harder.
      FixBotに聞いてみる
      コメントを追加
    5. iHome iH27B Power Connector Replacement: 手順 5、 1の画像 1
      • Slowly lift the plastic base towards you and lay it on the flat surface. The base should still be connected to the rest of the iHome by a few wires.
      • You should have visible access to most of the components inside the iHome now.
      FixBotに聞いてみる
      コメントを追加
    1. iHome iH27B Power Connector Replacement, Power Connector: 手順 6、 2の画像 1 iHome iH27B Power Connector Replacement, Power Connector: 手順 6、 2の画像 2
      • Firmly grasp the power connector, which is the plastic rectangular piece with the white and black wires connected to it.
      • Pull upwards and dislodge the connector.
      FixBotに聞いてみる
      コメントを追加
    2. iHome iH27B Power Connector Replacement: 手順 7、 1の画像 1
      • Using the scissors on your wire strippers, cut the connecting wires.
      • Using your wire strippers, remove about 1/4 " of the plastic tubing surrounding the end of your exposed wire, careful to not damage the wires.
      • Using a wire-nut or electrician's tape, connect the wires of the replacement power connector to your exposed wires. Connect white wire to white, and black to black.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
6人の作成者と共同で作成されました。
John Kraemer
メンバー登録日: 10/09/12
76 ポイント
9のガイドは作成済み
チーム
Cal Poly, Team 3-21, Amido Fall 2012 Cal Poly, Team 3-21, Amido Fall 2012人のメンバー
CPSU-AMIDO-F12S3G21
4 メンバー
36のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 11
過去 30 日: 41
今までの合計 2,524
