メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iHome IBT16 Battery Replacement
必要な工具と部品
  1. iHome IBT16 Battery Replacement, Base Plate: 手順 1、 2の画像 1 iHome IBT16 Battery Replacement, Base Plate: 手順 1、 2の画像 2
    • Make sure to flip the device over to get into the correct orientation
    • Using the Philips #00 Screwdriver, unscrew and remove the four 9mm black screws on the base plate of the device.
    • Make sure to keep these screws in a safe location so you don't lose them
    FixBotに聞いてみる
    コメントを追加
  2. iHome IBT16 Battery Replacement: 手順 2、 2の画像 1 iHome IBT16 Battery Replacement: 手順 2、 2の画像 2
    • Using the plastic opening tool, insert into the crack between the base plate and the main body of the device
    • Using a lever like motion, push the opening tool down thus lifting the plate
    • You will need to use your fingers to lift the base plate off the main body of the device
    • The motherboard is directly underneath the base plate
    FixBotに聞いてみる
    コメントを追加
  3. iHome IBT16 Battery Replacement, Battery: 手順 3、 1の画像 1
    • Inside the iHome remove the two 10mm silver Phillips screws that are on the motherboard.
    • Connect the ground strap to earth ground and put it around your wrist.
    FixBotに聞いてみる
    コメントを追加
  4. iHome IBT16 Battery Replacement: 手順 4、 1の画像 1
    • Take the motherboard out of the device, use the Plastic opening tool to ensure the power switch doesn't get stuck.
    • Don't pull too hard as you could possibly rip some wires or break the switch.
    FixBotに聞いてみる
    コメントを追加
  5. iHome IBT16 Battery Replacement: 手順 5、 1の画像 1
    • Take the battery out from underneath the motherboard.
    • The battery is connected to the motherboard, don't pull the battery too hard or too far from the motherboard.
    FixBotに聞いてみる
    コメントを追加
  6. iHome IBT16 Battery Replacement: 手順 6、 1の画像 1
    • Unsolder the black and red wires that are connected to the motherboard.
    • Don't hold the soldering iron to the solder joints for more than 10 seconds at a time.
    FixBotに聞いてみる
    コメントを追加
  7. iHome IBT16 Battery Replacement: 手順 7、 1の画像 1
    • Remove the bad battery by unsoldering the red wire from the B+ solder joint and the black wire from the B-
    FixBotに聞いてみる
    コメントを追加
終わりに
To put it all back together, solder the battery wires to the correct solder joints. Then place the battery back under the motherboard and screw the motherboard back on. After that put the face plate back on, and screw on the face plate
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Steven Ferreira
メンバー登録日: 03/08/17
222 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team S3-G6, Botvin Spring 2017 UMass Dartmouth, Team S3-G6, Botvin Spring 2017人のメンバー
UMASSD-BOTVIN-S17S3G6
2 メンバー
5のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 35
今までの合計 2,709
