この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
You can install hard drives up to 9mm thick.
必要な工具と部品
Use a coin to turn both battery locking screws 90 degrees to the left.
Remove the battery cover.
Remove the battery from the computer by pulling up on the plastic tab.
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free. Note that the keyboard ribbon is still attached to the logic board, so you cannot completely remove the keyboard yet.
If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw (between F4 and F5 key) 180 degrees in either direction and try again.
Rotate the keyboard away from the screen and rest it face-down on the trackpad area.
If the optical drive is not open, use a straightened paperclip to open it now.
Remove the 5 mm standoff.
Remove the following Phillips screws:
Remove the longer Phillips screw from the middle-rear of the modem shield.
Remove the three identical Phillips screws, two on either side of the EMI fingers, and the remaining one on the right side of the modem shield.
Remove the larger Phillips screw that secures the EMI fingers to the modem board.
Remove the EMI fingers.
Remove the Phillips screw from the left hinge.
Peel up the airport cable from beneath the yellow tape.
There are six screws to remove (if you have an iBook without Firewire the screw circled in orange will not be present):
Two short, flat-headed Phillips screws near the battery compartment.
One short, round-headed Phillips near the speaker cable connector. (This is present on some models, but not others - especially the older ones)
One short, flat-headed Phillips between the ethernet and USB ports.
One short, flat-headed Phillips to the left of the hole-y (polite laughter) area.
One long, round-headed Phillips screw near the power receptacle.
Take the metal bracket away from the hard drive.
Disconnect the hard drive cable from the hard drive by applying even pressure on both sides while maintaining a firm grip on the drive itself.
81 の人々がこのガイドを完成させました。
添付文書
8 件のコメント
after several assembly and disassemblies I found an SSD solution that works - essentially a PATA/EID to SD card adaptor from ebay (china source) for a few bucks and then I used carbon copy cloner to image and clone the active 6GB disk. My failed attempts involved 32GB SSD from Kingspan - would not boot (with any Jumper setting - very frustrating with a 30min each assemble/disassemble to test!)
Hi, thanks for the SD card adapter suggestion. Super helpful. Are you able to provide a link or item name please for the adapter? Thank you.
Great guide, I followed to the end. I swapped out my drive for a compact flash adapter and a 16GB card. My Clamshell runs absolutely silently. I’m hoping this will extend the battery life, too.
One thing I noticed when putting the display back on is the segment between the joints had to fit on to some hooks on the lower part of the case. That allowed the tiny screw holes between the joints to line up nicely.
Made the mistake of not fitting these hooks on the lower part of the case before finishing disassembly - I was wondering why the clutch cover was so difficult to re-attach, and this was the culprit. Thanks for this comment
