メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Zoomer Show Pony Leg Spring Replacement
必要な工具と部品
  1. Zoomer Show Pony Leg Spring Replacement, Power and Volume Switch: 手順 1、 3の画像 1 Zoomer Show Pony Leg Spring Replacement, Power and Volume Switch: 手順 1、 3の画像 2 Zoomer Show Pony Leg Spring Replacement, Power and Volume Switch: 手順 1、 3の画像 3
    • Flip the pony over.
    • Remove the five Triangle 3 screws from underneath.
    • The pony will separate into a few pieces once the screws are removed.
    FixBotに聞いてみる
    コメントを追加
  2. Zoomer Show Pony Leg Spring Replacement: 手順 2、 3の画像 1 Zoomer Show Pony Leg Spring Replacement: 手順 2、 3の画像 2 Zoomer Show Pony Leg Spring Replacement: 手順 2、 3の画像 3
    • Disconnect all of the wires between the head and leg sections.
    • To replace the power/volume switch, remove the two Phillips #0 screws from the switch.
    • Lift the switch out to replace.
    FixBotに聞いてみる
    コメントを追加
  3. Zoomer Show Pony Leg Spring Replacement, Speaker: 手順 3、 1の画像 1
    • Remove the black bar by unscrewing the two triangle screws marked in yellow. These screws are recessed into the black bar so you may need an extender for your triangle bit.
    FixBotに聞いてみる
    コメントを追加
  4. Zoomer Show Pony Leg Spring Replacement: 手順 4、 2の画像 1 Zoomer Show Pony Leg Spring Replacement: 手順 4、 2の画像 2
    • If you are not replacing the pony's speaker, skip the next bullet point.
    • Lift out the speaker, again making sure that it is disconnected, and replace with a new one.
    FixBotに聞いてみる
    コメントを追加
  5. Zoomer Show Pony Leg Spring Replacement, Leg Spring: 手順 5、 3の画像 1 Zoomer Show Pony Leg Spring Replacement, Leg Spring: 手順 5、 3の画像 2 Zoomer Show Pony Leg Spring Replacement, Leg Spring: 手順 5、 3の画像 3
    • Remove all five triangular screws located on the backside of the leg.
    • Remove the Phillips head screw holding the white leg bracket.
    • The white bracket MUST be re-connected in the same orientation. Make sure to note which side is up and down. The part looks symmetric to the blind eye but it is not.
    • Detach the plastic mount at the top of the leg by sliding it in a vertical motion from the position shown.
    FixBotに聞いてみる
    コメントを追加
  6. Zoomer Show Pony Leg Spring Replacement: 手順 6、 3の画像 1 Zoomer Show Pony Leg Spring Replacement: 手順 6、 3の画像 2 Zoomer Show Pony Leg Spring Replacement: 手順 6、 3の画像 3
    • Lift up on the plastic housing located on the upper portion of the leg (where it connects to the body).
    • Carefully separate the plastic housing at the base of the leg.
    • Remove slowly, there are small components attached to the motor that could become loose and/or missing.
    FixBotに聞いてみる
    コメントを追加
  7. Zoomer Show Pony Leg Spring Replacement: 手順 7、 1の画像 1
    • The spring will be exposed as shown. Remove the broken or damaged spring and replace it with a new one.
    • Spring must be in the "loaded position" when reassembling (there should be some resistance).
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
2人の作成者と共同で作成されました。
James
メンバー登録日: 01/25/18
97 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team S20-G5, Passmore Spring 2018 USF Tampa, Team S20-G5, Passmore Spring 2018人のメンバー
USFT-PASSMORE-S18S20G5
4 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 54
今までの合計 709
