メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Zoom H6 Handy Recorder Battery Terminal Replacement
必要な工具と部品
    1. Zoom H6 Handy Recorder Battery Terminal Replacement, Battery Terminal: 手順 1、 1の画像 1
      • Place device on table facing down.
      • Remove the battery cover, with index finger press protruding tab towards "OPEN".
      FixBotに聞いてみる
      コメントを追加
    2. Zoom H6 Handy Recorder Battery Terminal Replacement: 手順 2、 1の画像 1
      • If batteries are present, remove them in order to reveal the terminals at the bottom of the device.
      FixBotに聞いてみる
      コメントを追加
    3. Zoom H6 Handy Recorder Battery Terminal Replacement: 手順 3、 3の画像 1 Zoom H6 Handy Recorder Battery Terminal Replacement: 手順 3、 3の画像 2 Zoom H6 Handy Recorder Battery Terminal Replacement: 手順 3、 3の画像 3
      • With the flat end of the black plastic spudger, pry the terminal away from the case.
      • Use the small blue plastic opening tool to lift the terminal out of the device. Repeat for the adjacent terminal.
      • When lifting the terminal out, the metal wire of the terminal must move past the plastic protrusion that keeps the battery terminal in place.
      FixBotに聞いてみる
      コメントを追加
    4. Zoom H6 Handy Recorder Battery Terminal Replacement: 手順 4、 1の画像 1
      • Remove four rubber feet using fingernails to access the four screws underneath.
      FixBotに聞いてみる
      コメントを追加
    5. Zoom H6 Handy Recorder Battery Terminal Replacement: 手順 5、 2の画像 1 Zoom H6 Handy Recorder Battery Terminal Replacement: 手順 5、 2の画像 2
      • For the terminals directly connected to the motherboard, unscrew eight (PH #1), 9 mm screws (two located on the top back side, two in the center of back side of device right above the battery cover, and four under the rubber feet).
      • An electronics screwdriver narrow enough to fit in hole (3.5mm diameter), but long enough to reach the screws (at least 2cm) will be required to unscrew the two screws in the center of back side of the device.
      FixBotに聞いてみる
      コメントを追加
    6. Zoom H6 Handy Recorder Battery Terminal Replacement: 手順 6、 2の画像 1 Zoom H6 Handy Recorder Battery Terminal Replacement: 手順 6、 2の画像 2
      • Place device face up and remove the four knobs using the flat end of the plastic opening tool.
      FixBotに聞いてみる
      コメントを追加
    7. Zoom H6 Handy Recorder Battery Terminal Replacement: 手順 7、 3の画像 1 Zoom H6 Handy Recorder Battery Terminal Replacement: 手順 7、 3の画像 2 Zoom H6 Handy Recorder Battery Terminal Replacement: 手順 7、 3の画像 3
      • Carefully lift up the top of the device and gently set aside.
      FixBotに聞いてみる
      コメントを追加
    8. Zoom H6 Handy Recorder Battery Terminal Replacement: 手順 8、 3の画像 1 Zoom H6 Handy Recorder Battery Terminal Replacement: 手順 8、 3の画像 2 Zoom H6 Handy Recorder Battery Terminal Replacement: 手順 8、 3の画像 3
      • Unscrew three (PH #1), 7mm screws from the button board near the display and gently flip over.
      FixBotに聞いてみる
      コメントを追加
    9. Zoom H6 Handy Recorder Battery Terminal Replacement: 手順 9、 3の画像 1 Zoom H6 Handy Recorder Battery Terminal Replacement: 手順 9、 3の画像 2 Zoom H6 Handy Recorder Battery Terminal Replacement: 手順 9、 3の画像 3
      • Using a plastic opening tool, unlatch the clip and carefully unplug the ribbon connector from the device.
      • Set the button board aside.
      FixBotに聞いてみる
      コメントを追加
    10. Zoom H6 Handy Recorder Battery Terminal Replacement: 手順 10、 1の画像 1
      • Unscrew four (PH #1), 8mm screws from the motherboard.
      FixBotに聞いてみる
      コメントを追加
    11. Zoom H6 Handy Recorder Battery Terminal Replacement: 手順 11、 1の画像 1
      この手順で使用する道具:
      • Disconnect wire from motherboard using tweezers.
      • Do not touch the motherboard with metal tweezers. Only touch the plastic part of the plugged-in wire.
      FixBotに聞いてみる
      コメントを追加
    12. Zoom H6 Handy Recorder Battery Terminal Replacement: 手順 12、 1の画像 1
      • Turn device 180 degrees to unscrew two (PH #1), 8mm screws from the mic connector.
      FixBotに聞いてみる
      コメントを追加
    13. Zoom H6 Handy Recorder Battery Terminal Replacement: 手順 13、 3の画像 1 Zoom H6 Handy Recorder Battery Terminal Replacement: 手順 13、 3の画像 2 Zoom H6 Handy Recorder Battery Terminal Replacement: 手順 13、 3の画像 3
      • Gently remove three ribbon connectors from the base of the device. One is connected to the mic connector, the other two are on the top of the device next to the "LINE OUT" plug-in (directly behind the device display screen).
      • Use tweezers to remove the two ribbon connectors behind the display screen because it is difficult to remove them only using hands.
      • Avoid touching anything but the ribbon connectors with the metal tweezers.
      FixBotに聞いてみる
      コメントを追加
    14. Zoom H6 Handy Recorder Battery Terminal Replacement: 手順 14、 2の画像 1 Zoom H6 Handy Recorder Battery Terminal Replacement: 手順 14、 2の画像 2
      • Gently lift off motherboard from the base of the device.
      FixBotに聞いてみる
      コメントを追加
    15. Zoom H6 Handy Recorder Battery Terminal Replacement: 手順 15、 2の画像 1 Zoom H6 Handy Recorder Battery Terminal Replacement: 手順 15、 2の画像 2
      • Taking care not to damage other components on the motherboard, use a soldering iron to undo the soldering that holds the terminals to the motherboard.
      FixBotに聞いてみる
      コメントを追加
    16. Zoom H6 Handy Recorder Battery Terminal Replacement: 手順 16、 3の画像 1 Zoom H6 Handy Recorder Battery Terminal Replacement: 手順 16、 3の画像 2 Zoom H6 Handy Recorder Battery Terminal Replacement: 手順 16、 3の画像 3
      • Flip motherboard over and remove the black tape covering the battery terminal.
      • Replace with new terminal.
      • Resolder the terminals to the motherboard.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
4 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Rachel Calder
メンバー登録日: 02/14/18
1,273 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team S5-G2, Eyestone Spring 2018 USF Tampa, Team S5-G2, Eyestone Spring 2018人のメンバー
USFT-EYESTONE-S18S5G2
4 メンバー
26のガイドは作成済み
2件のガイドコメント
Where can I buy the battery compartment please?
Lee - 返信 共有
Where to buy the wire battery contact part?
ericyeong@gmail.com - 返信 共有
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 22
過去 30 日: 117
今までの合計 6,928
