はじめに
Welcome to the Zoom H1 Handy Recorder guide to replace the battery terminal. It will happen at times that the battery terminal corrodes, suffers damage, or ages in quality, making the device not work properly or cease to turn on in general. This guide will provide step-by-step instructions to help you replace the battery terminal. Although this guide is easy to follow, there is a special skill necessary: soldering.
Caution! About soldering: there are some hazards to be aware of, necessary equipment, and the act of soldering itself. Luckily, iFixit has a Wiki on all of the above! Click here to access the Wiki. Now go and make your Zoom H1 Handy Recorder work like new again!
必要な工具と部品
To Re-construct device, perform these steps in reverse order.
7件のガイドコメント
Caution is needed with step 5. My backside broke off using a spudger to attempt to remove.
Joe Vaughan - 返信 共有
Mine has third screw under the serial-number sticker.
halluciana - 返信 共有
Can anyone advise where to find replacement terminals? My zoom h1 has bad corrosion of its battery terminals and I would like to follow this guide to fix them! Thanks!
