メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Zebra ZP 450 Feed Key Replacement
必要な工具と部品
  1. Zebra ZP 450 Feed Key Replacement, Open Lid and Unscrew Screws: 手順 1、 2の画像 1 Zebra ZP 450 Feed Key Replacement, Open Lid and Unscrew Screws: 手順 1、 2の画像 2
    • This device uses electricity, so it is best to unplug it before going any farther.
    • Remove 5 11.08mm Phillips screws that will come out of the casing once loose.
    • There is one Phillips screw at the bottom center set deep inside the casing - it is easy to get to with a thin screwdriver. This screw will come loose, but stay inside the casing. Don't be surprised when it won't drop out.
    FixBotに聞いてみる
    コメントを追加
  2. Zebra ZP 450 Feed Key Replacement, Remove Top: 手順 2、 1の画像 1
    • Position your hands one on either side of the top.
    • Put your thumbs on the front and your 4 fingers on the sides.
    • Push outwards with your 4 fingers to remove the plastic top.
    • Wiggling the top may help loosen it from the bottom screw that is still in the case.
    FixBotに聞いてみる
    コメントを追加
  3. Zebra ZP 450 Feed Key Replacement, Open Lid: 手順 3、 2の画像 1 Zebra ZP 450 Feed Key Replacement, Open Lid: 手順 3、 2の画像 2
    • Put the lid back down and lay the top open as shown in the photo.
    • Be careful setting the lid down, as it could pull wiring from other components. If you need more wiggle room, you can remove the silver cable from the support clip on the side, as seen in the second photo by pulling the tab back and pushing the cable up.
    • The component we are replacing is on the underneath of the top of the device, highlighted in the photo
    FixBotに聞いてみる
    コメントを追加
  4. Zebra ZP 450 Feed Key Replacement, Remove No-Fuss Ribbon Cable Connectors: 手順 4、 2の画像 1 Zebra ZP 450 Feed Key Replacement, Remove No-Fuss Ribbon Cable Connectors: 手順 4、 2の画像 2
    • Starting with either ribbon cable, grip it on either side and gently pull out - The cable will come out of it's connector.
    • Repeat for other ribbon cable
    • Ribbons may be fragile, so handle with care.
    FixBotに聞いてみる
    コメントを追加
  5. Zebra ZP 450 Feed Key Replacement, Remove Circuit Board: 手順 5、 3の画像 1 Zebra ZP 450 Feed Key Replacement, Remove Circuit Board: 手順 5、 3の画像 2 Zebra ZP 450 Feed Key Replacement, Remove Circuit Board: 手順 5、 3の画像 3
    • Remove 2 7.51mm Phillips screws holding the circuit board onto the device casing.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Keeland Roche
メンバー登録日: 10/11/14
158 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 1-28, Donnelly Fall 2014 USF Tampa, Team 1-28, Donnelly Fall 2014人のメンバー
USFT-DONNELLY-F14S1G28
1 メンバー
2のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 28
今までの合計 2,157
