はじめに
If you are having problems with the velcro on your ZCWA BR151 vacuum, use this guide to replace it. The velcro is easily accessible as it is merely on the underside of the attachment and on the device itself, so there is no need to remove any additional parts to access it. You will not need to do any difficult steps, but step 5 gives you the option to use a hot glue gun. If you use a hot glue gun, then make sure to use it carefully to prevent burns.
必要な工具と部品
Turn off the device.
Flip the device over to access the bottom panel.
Remove the cloth mop covering by lifting it from the velcro on the plastic mop attachment.
Remove the plastic mop attachment by placing your fingers underneath and prying it up.
ある他の人がこのガイドを完成しました。
