はじめに
Use this guide to install or replace a new sprayer or pump for the ZCWA BR151. The part itself functions as the primary way for water to lightly jet out of the device's mopping feature. The replacement of this part could prevent any leaking that the device may be experiencing. To access the sprayer/pump, several pieces will need to be removed from the device. Before beginning, make sure the device is turned off and the water tank is empty of any water.
必要な工具と部品
Flip the device over to access the bottom panel.
Remove the cloth mop covering by lifting it from the velcro on the plastic mop attachment.
Remove the plastic mop attachment by placing your fingers underneath and prying it up.
Turn the device around so that the motherboard is closest to you.
Track the red and black wire cables from the sprayer/pump to the motherboard.
Remove the sprayer/pump wiring from the port on the motherboard by pinching the silver brackets and pull the wire casing away from the motherboard.
Pull evenly on the full width of the cable so that no individual wires are overly strained.
Remove the sprayer/pump from the vacuum.
2 の人々がこのガイドを完成させました。
