メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Yobo Gameware Controller Trigger Spring Replacement
必要な工具と部品
  1. Yobo Gameware Controller Trigger Spring Replacement, Back Panel: 手順 1、 2の画像 1 Yobo Gameware Controller Trigger Spring Replacement, Back Panel: 手順 1、 2の画像 2
    • Be sure the controller is disconnected from the console or any source of power.
    • Place the controller (button - side down) on a clean, solid work surface.
    • Use your screwdriver to remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
    FixBotに聞いてみる
    コメントを追加
  2. Yobo Gameware Controller Trigger Spring Replacement, Removing Back Panel: 手順 2、 2の画像 1 Yobo Gameware Controller Trigger Spring Replacement, Removing Back Panel: 手順 2、 2の画像 2
    • Gently life the back panel up, separating it from the front panel.
    • Some components could fall off the front panel if the controller is knocked around during this step.
    FixBotに聞いてみる
    コメントを追加
  3. Yobo Gameware Controller Trigger Spring Replacement, Removing Triggers: 手順 3、 3の画像 1 Yobo Gameware Controller Trigger Spring Replacement, Removing Triggers: 手順 3、 3の画像 2 Yobo Gameware Controller Trigger Spring Replacement, Removing Triggers: 手順 3、 3の画像 3
    • Depress the trigger assembly using your index finger while using your thumb to keep upward pressure on the grey square bracket and clear circular component on the underside of the trigger assembly.
    • Maintain a firm grip on the entire assembly, as the components could spring apart if you release pressure.
    • Rotate the assembly upwards and towards you to remove it from its housing in the controller.
    • The removal process is the same for both the left and right triggers.
    FixBotに聞いてみる
    コメントを追加
  4. Yobo Gameware Controller Trigger Spring Replacement, Replacing Spring: 手順 4、 2の画像 1 Yobo Gameware Controller Trigger Spring Replacement, Replacing Spring: 手順 4、 2の画像 2
    • Gently release pressure on the trigger assembly, allowing the components to come apart on your work surface.
    • A new spring may now be incorporated into the designated trigger assembly.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
1人の作成者と共同作成されました。
Shoaf
メンバー登録日: 04/12/22
109 ポイント
1ガイドが承認済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 9
過去 30 日: 59
今までの合計 948
