メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Xiaomi Redmi Note Front-Facing Camera Replacement
必要な工具と部品
  1. Xiaomi Redmi Note Front-Facing Camera Replacement, Battery: 手順 1、 1の画像 1
    • Make sure the Xiaomi Redmi Note is powered off before removing the battery.
    • Insert the plastic opening tool between the charging port and the rear case.
    • Pry the end of the rear case up from the charging port.
    FixBotに聞いてみる
    コメントを追加
  2. Xiaomi Redmi Note Front-Facing Camera Replacement: 手順 2、 2の画像 1 Xiaomi Redmi Note Front-Facing Camera Replacement: 手順 2、 2の画像 2
    • Run the plastic opening tool along the seam on the side of the phone to remove the rear casing.
    FixBotに聞いてみる
    コメントを追加
  3. Xiaomi Redmi Note Front-Facing Camera Replacement: 手順 3、 2の画像 1 Xiaomi Redmi Note Front-Facing Camera Replacement: 手順 3、 2の画像 2
    • Locate the indentation at the bottom of the battery.
    • Place a finger in the indentation and lift up to remove the battery.
    FixBotに聞いてみる
    コメントを追加
  4. Xiaomi Redmi Note Front-Facing Camera Replacement, Midframe: 手順 4、 2の画像 1 Xiaomi Redmi Note Front-Facing Camera Replacement, Midframe: 手順 4、 2の画像 2
    • Remove twelve 3.5mm Phillips #00 screws from the midframe.
    FixBotに聞いてみる
    コメントを追加
  5. Xiaomi Redmi Note Front-Facing Camera Replacement: 手順 5、 2の画像 1 Xiaomi Redmi Note Front-Facing Camera Replacement: 手順 5、 2の画像 2
    • Insert a plastic opening into the seam between the midframe and the bottom frame of the phone.
    • Run the plastic opening tool along the seam.
    • Pry up the midframe with the plastic opening tool.
    • Once the midframe has been sufficiently lifted with the tool, place a hand underneath the edge to lift the entire component out of the frame.
    • There will be snapping sounds as the clips on the midframe disconnect from the phone.
    FixBotに聞いてみる
    コメントを追加
  6. Xiaomi Redmi Note Front-Facing Camera Replacement, Front-Facing Camera: 手順 6、 3の画像 1 Xiaomi Redmi Note Front-Facing Camera Replacement, Front-Facing Camera: 手順 6、 3の画像 2 Xiaomi Redmi Note Front-Facing Camera Replacement, Front-Facing Camera: 手順 6、 3の画像 3
    この手順で使用する道具:
    • Use tweezers to lift the retaining flap of the zero insertion force (ZIF) connector to the upright position.
    • Use tweezers to pull the ribbon cable out of the ZIF connector.
    • Remove the front-facing camera from the motherboard.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Caitlin Settles
メンバー登録日: 04/26/17
789 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S22-G4, Livingston Spring 2017 Cal Poly, Team S22-G4, Livingston Spring 2017人のメンバー
CPSU-LIVINGSTON-S17S22G4
4 メンバー
24のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 45
今までの合計 2,021
