メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Xbox One Stereo Headset Adapter Buttons Replacement
必要な工具と部品
  1. Xbox One Stereo Headset Adapter Buttons Replacement, Adapter Buttons: 手順 1、 2の画像 1 Xbox One Stereo Headset Adapter Buttons Replacement, Adapter Buttons: 手順 1、 2の画像 2
    • Insert the flat edge of a metal spudger in the seam between the adapter body and the plastic casing. Move the spudger into one of the corners.
    • Push down on the spudger to separate the casing from the adapter until you hear a click and the casing stays open on that side.
    • Do the same to the other side until the casing comes off.
    • When reassembling, first align the headphone jack in the back of the adapter body with the hole in the casing, then align the tabs on the floor of the casing with the holes in the bottom of the adapter body.
    FixBotに聞いてみる
    コメントを追加
  2. Xbox One Stereo Headset Adapter Buttons Replacement: 手順 2、 1の画像 1
    • Remove three 5.0 mm T5 Security Torx screws along the edges of the controller housing.
    • Remove two 8.0 mm T5 Security Torx screws near the top-center of the adapter.
    FixBotに聞いてみる
    コメントを追加
  3. Xbox One Stereo Headset Adapter Buttons Replacement: 手順 3、 1の画像 1
    • With your fingers, carefully lift the adapter housing from the button panel.
    • Be careful not to yank the wires connecting the two halves of the circuit board.
    FixBotに聞いてみる
    コメントを追加
  4. Xbox One Stereo Headset Adapter Buttons Replacement: 手順 4、 1の画像 1
    • Pull back on the controller USB connector with your finger to separate the main adapter circuit board from the rubber mold in the button panel.
    FixBotに聞いてみる
    コメントを追加
  5. Xbox One Stereo Headset Adapter Buttons Replacement: 手順 5、 1の画像 1
    • With your fingers, partially peel back the rubber molding near the button you want to replace.
    • Do not rip the rubber mold. The mold will need to be used for the new button, and it must remain intact in order for the button to work properly.
    • Using the straight, pointed end of a small pointed spudger, scrape off the glue between the plastic button and the rubber mold.
    FixBotに聞いてみる
    コメントを追加
  6. Xbox One Stereo Headset Adapter Buttons Replacement: 手順 6、 1の画像 1
    この手順で使用する道具:
    • Grip the plastic tabs on either side of the button with tweezers.
    • Squeeze the tweezers to pop the button out the front face of the button panel.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
4人の作成者と共同で作成されました。
Justin Rosescu
メンバー登録日: 01/30/15
500 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 17-37, Amido Winter 2015 Cal Poly, Team 17-37, Amido Winter 2015人のメンバー
CPSU-AMIDO-W15S17G37
4 メンバー
5のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 9
過去 30 日: 43
今までの合計 6,979
