メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Xbox One Kinect Colour Camera Replacement
必要な工具と部品
  1. Xbox One Kinect Colour Camera Replacement, Outer Shell: 手順 1、 1の画像 1
    • Remove the sticker on the underside of the device.
    • Remove the four 3.1x23.5 mm T10 screws underneath the sticker.
    • While you're at it, remove the four 3.1x7.5 mm T10 screws beneath the sticker. Make note of the sizes and locations of the screws.
    FixBotに聞いてみる
    コメントを追加
  2. Xbox One Kinect Colour Camera Replacement: 手順 2、 3の画像 1 Xbox One Kinect Colour Camera Replacement: 手順 2、 3の画像 2 Xbox One Kinect Colour Camera Replacement: 手順 2、 3の画像 3
    • Remove the back panel.
    • Remove the black panels on either side of the Kinect, and remove the 3.1x7.5mm T10 screws underneath them.
    FixBotに聞いてみる
    コメントを追加
  3. Xbox One Kinect Colour Camera Replacement: 手順 3、 3の画像 1 Xbox One Kinect Colour Camera Replacement: 手順 3、 3の画像 2 Xbox One Kinect Colour Camera Replacement: 手順 3、 3の画像 3
    • Using your thumbs, press firmly against the outer case on either side of the stand. This will disengage the internal assembly.
    • Lift the internal assembly with the spudger.
    • Remove the assembly from the case. You now have access to the inner shell of the kinect, along with the heat sink, microphone, and LED sensor.
    FixBotに聞いてみる
    コメントを追加
  4. Xbox One Kinect Colour Camera Replacement, Heat Sink Assembly: 手順 4、 2の画像 1 Xbox One Kinect Colour Camera Replacement, Heat Sink Assembly: 手順 4、 2の画像 2
    • Remove the eight 2.9x7.6 mm T9 screws from the rear of the internal case.
    • Lift the internal metal case from the plastic shell enclosing the heat sink assembly.
    FixBotに聞いてみる
    コメントを追加
  5. Xbox One Kinect Colour Camera Replacement: 手順 5、 3の画像 1 Xbox One Kinect Colour Camera Replacement: 手順 5、 3の画像 2 Xbox One Kinect Colour Camera Replacement: 手順 5、 3の画像 3
    • Disconnect the ribbon cable between the sensor driver board and the motherboard.
    • Remove the 3.0x7.5 mm T9 screw holding the sensor driver board to the heat sink.
    • Remove the infrared sensor board for the Kinect.
    FixBotに聞いてみる
    コメントを追加
  6. Xbox One Kinect Colour Camera Replacement: 手順 6、 3の画像 1 Xbox One Kinect Colour Camera Replacement: 手順 6、 3の画像 2 Xbox One Kinect Colour Camera Replacement: 手順 6、 3の画像 3
    この手順で使用する道具:
    • Detach the ribbon cable leading to the microphone with the tweezers.
    • Remove the four 3.1x7.7 mm T9 screws connecting the microphone to the heat sink assembly.
    • Remove the stand.
    FixBotに聞いてみる
    コメントを追加
  7. Xbox One Kinect Colour Camera Replacement: 手順 7、 3の画像 1 Xbox One Kinect Colour Camera Replacement: 手順 7、 3の画像 2 Xbox One Kinect Colour Camera Replacement: 手順 7、 3の画像 3
    • Remove the eight 3.0x7.6 mm T9 screws from the motherboard.
    • Peel away the plastic film from the motherboard using the spudger.
    • Detach the ribbon cable leading to the color camera using the spudger.
    FixBotに聞いてみる
    コメントを追加
  8. Xbox One Kinect Colour Camera Replacement: 手順 8、 3の画像 1 Xbox One Kinect Colour Camera Replacement: 手順 8、 3の画像 2 Xbox One Kinect Colour Camera Replacement: 手順 8、 3の画像 3
    • Lift the motherboard and the heat sink assembly from the plastic shell. The components attached to the heat sink are now accessible.
    FixBotに聞いてみる
    コメントを追加
  9. Xbox One Kinect Colour Camera Replacement, Colour Camera: 手順 9、 3の画像 1 Xbox One Kinect Colour Camera Replacement, Colour Camera: 手順 9、 3の画像 2 Xbox One Kinect Colour Camera Replacement, Colour Camera: 手順 9、 3の画像 3
    • Go ahead and start by removing the Colour Camera's lens cap. This way you can remove the Camera without anything in your way.
    FixBotに聞いてみる
    コメントを追加
  10. Xbox One Kinect Colour Camera Replacement: 手順 10、 2の画像 1 Xbox One Kinect Colour Camera Replacement: 手順 10、 2の画像 2
    • Using the T5 screwdriver, remove the four 1.9x10.2 mm screws from the four corners of the camera.
    • With the spudger inserted in between the camera and the metal casing, carefully prop up the camera.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Malak Anshassi
メンバー登録日: 09/22/14
356 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 1-3, Hickman Fall 2014 USF Tampa, Team 1-3, Hickman Fall 2014人のメンバー
USFT-HICKMAN-F14S1G3
4 メンバー
7のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 12
過去 30 日: 49
今までの合計 2,282
