メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Withings Smart Body Analyzer Pressure Sensor Replacement
必要な工具と部品
    1. Withings Smart Body Analyzer Pressure Sensor Replacement, Withings Smart Body Analyzer Disassembly: 手順 1、 1の画像 1
      • Push the battery door
      • Open the compartment
      • Gently remove the batteries from their designated positions
      • Place them aside, away from the reach of children
      FixBotに聞いてみる
      コメントを追加
    2. Withings Smart Body Analyzer Pressure Sensor Replacement: 手順 2、 3の画像 1 Withings Smart Body Analyzer Pressure Sensor Replacement: 手順 2、 3の画像 2 Withings Smart Body Analyzer Pressure Sensor Replacement: 手順 2、 3の画像 3
      • With caution, insert the plastic opening tools in between the disk and the glass face
      • It's a tight fit, so don't be afraid to apply a little bit of force
      • As soon as you hear a faint crackling sound, that means that the adhesive is budging out of place
      • Gently rotate the plastic spudger around the disk to get around the adhesive
      • Gently lift the metal disk
      • After the disk has been lifted, a wire and a small copper plate can be seen attached to the back of the disk
      • Carefully remove the wire and plate by peeling back the adhesive sticker that has been positioned around them
      FixBotに聞いてみる
      コメントを追加
    3. Withings Smart Body Analyzer Pressure Sensor Replacement: 手順 3、 2の画像 1 Withings Smart Body Analyzer Pressure Sensor Replacement: 手順 3、 2の画像 2
      • After all the above steps have been completed, proceed by removing the glass face
      • Carefully insert a plasic spudger in the small gap that exist in between the glass face and the plastic back
      • Run the plastic spudger all around the scale to increase the gap size
      • Place a plastic spudger in every corner, since the feet of the scale are also attached to the glass face using adhesive
      • Carefully insert the metal spudger underneath the adhesive that is located underneath the feet of the scale, and gently keep pushing until the adhesive is out of place
      • Repeat the above steps four times
      • After all the adhesives has been removed, gently lift the glass face off
      FixBotに聞いてみる
      コメントを追加
    1. Withings Smart Body Analyzer Pressure Sensor Replacement, Pressure Sensor: 手順 4、 1の画像 1
      • Notice the red and black wires connecting the circuit board to each of the pressure sensors.
      • Using a soldering iron and de-soldering braid, remove the soldered red and black wires from the circuit board
      FixBotに聞いてみる
      コメントを追加
    2. Withings Smart Body Analyzer Pressure Sensor Replacement: 手順 5、 2の画像 1 Withings Smart Body Analyzer Pressure Sensor Replacement: 手順 5、 2の画像 2
      • Use a Phillips-head screwdriver to remove the screw from the sensor. There will be two screws per sensor.
      FixBotに聞いてみる
      コメントを追加
    3. Withings Smart Body Analyzer Pressure Sensor Replacement: 手順 6、 2の画像 1 Withings Smart Body Analyzer Pressure Sensor Replacement: 手順 6、 2の画像 2
      • Remove any sensors you need and you are now ready to replace or repair depending on your needs.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Ashley Dauphinee
メンバー登録日: 03/22/17
323 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team S4-G1, Julie Spring 2017 UMass Dartmouth, Team S4-G1, Julie Spring 2017人のメンバー
UMASSD-JULIE-S17S4G1
4 メンバー
5のガイドは作成済み
3件のガイドコメント
Where do I get those replacements?
karina - 返信 共有
where can I buy pressure sensors?
Andrey Kolesov - 返信 共有
The issue is not the pressure sensor, but a weak area within the foot.
Having taken my scales apart to repair them I found the the foot (pictured within the plastic ring above) has a metal disc in it, that is supported by a few weak plastic ribs that easily damage. I filled them in with Araldyte to create a firm level surface and all is good again.
As a design engineer who fault-finds all day, I would say this is either poor design (an oversight), or brilliant salesmanship (a weak point that allows Withings to sell more scales). Which is true? Only they know.
FlashingIcon - 返信 共有
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 13
過去 30 日: 50
今までの合計 4,786
