メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Wireless Card Replacement
必要な工具と部品
  1. Wireless Card  Replacement, HP 17-x061nr  Disassembly: 手順 1、 3の画像 1 Wireless Card  Replacement, HP 17-x061nr  Disassembly: 手順 1、 3の画像 2 Wireless Card  Replacement, HP 17-x061nr  Disassembly: 手順 1、 3の画像 3
    • With the laptop upside down, remove the battery by hand and the twelve 7.0 mm screws that are holding the back case to the front. Use a JIS #0 screwdriver to remove the screws.
    FixBotに聞いてみる
    コメントを追加
  2. Wireless Card  Replacement: 手順 2、 2の画像 1 Wireless Card  Replacement: 手順 2、 2の画像 2
    • Peel back the rubber footrests located next to the battery, on the left and right sides.
    • Remove the two 7.0 mm screws underneath the rubber feet using a JIS #0 screwdriver.
    FixBotに聞いてみる
    コメントを追加
  3. Wireless Card  Replacement: 手順 3、 1の画像 1
    • Slide the optical drive out and away from the laptop.
    FixBotに聞いてみる
    コメントを追加
  4. Wireless Card  Replacement: 手順 4、 3の画像 1 Wireless Card  Replacement: 手順 4、 3の画像 2 Wireless Card  Replacement: 手順 4、 3の画像 3
    • Flip the computer over and use a plastic opening tool to wedge between the back and front cases.
    • Trace the perimeter of the laptop. Make sure to keep the tool inserted between the front and back cases. You will hear popping sounds as the back case becomes disengaged from the front plate.
    • Flip the laptop over and lift the back case off. Now you have access to all of the internal hardware.
    FixBotに聞いてみる
    コメントを追加
  5. Wireless Card  Replacement, Wireless Card: 手順 5、 2の画像 1 Wireless Card  Replacement, Wireless Card: 手順 5、 2の画像 2
    • Locate the wireless card in the center of the computer and attached to the motherboard.
    • Locate the 4.0 mm hidden screw holding the wireless card and gently remove it.
    FixBotに聞いてみる
    コメントを追加
  6. Wireless Card  Replacement: 手順 6、 2の画像 1 Wireless Card  Replacement: 手順 6、 2の画像 2
    • Remove the old wireless card and replace with the new wireless card. Gently screw it into place.
    • Be sure to keep the replacement within the package until you are ready to place it.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Curtis Haley
メンバー登録日: 02/23/18
520 ポイント
3のガイドは作成済み
チーム
Washington State, Team S1-G1, Lobnitz Spring 2018 Washington State, Team S1-G1, Lobnitz Spring 2018人のメンバー
WSU-LOBNITZ-S18S1G1
5 メンバー
5のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 29
過去 30 日: 110
今までの合計 10,699
