はじめに
This description takes you through the steps of changing a spool and feeding a new thread into the wire bonder.
ビデオの概要
Remove the seal from the wire spool. Take care not to cut the thread at the red marking!
Place the thread between the guides of the infeeder.
Pull the engaging knob which is situated to the left of the infeeder rolls, to the left.
Now there is a gap between the infeeder rolls into which the wire can be inserted safely.
Cut the wire.
Place the wire behind the sensors (the black box in the foreground).
この手順で使用する道具:Tweezers$4.99
Use the tweezers to place the wire between the two metal guides of the outfeeder.
Push the spring of the outfeeder and the "Feed and Capture" button simultaneously for automatic feeding.
Make sure that the rolls of the outfeeder are close together so that the wire is gripped firmly.
Before starting automatic feeding, turn off "Run or Service" and activate "Feed or Capture".
It is also possible to feed the wire manually into the outfeeder tube.
In order to do so, press the "Run and Service" button and turn the left-hand wheel clockwise. The wire is now fed ino the tube.
