はじめに
The main troubleshooting solution is to remove then reinstall the batteries, or replace dead batteries. This is also the first step in any other replacement for this toy.
必要な工具と部品
There are two screws that require a 4.0mm flat head screwdriver. Twist them counter clockwise to remove. When you remove them they stay contained within the blue outer case.
ある他の人がこのガイドを完成しました。
